Re: Exit Code 13 [message #672378 is a reply to message #672369] |
Fri, 20 May 2011 21:07 |
I'm confused, Judy. You say you're on a 64-bit Windows platform and
you've downloaded a 64-bit XDK (probably meant JDK), yet you've wired
eclipse.ini up to a 32-bit JRE.
The path to your JRE should be (personally, I don't advise using your
system's JRE--use a private copy of the JDK, but oh well...) something like:
C:\Program Files\java\jre6\bin\javaw.exe
No? Because on Windows 64-bit, C:\Program Files (x86) is the place where
32-bit apps are deposited.
Or have I misunderstood?
On 20-May-11 14:40, Judy Tyrer wrote:
> I read all the previous issues with using 64 bits and verified that I DO
> have the 64 bit XDK, I have the configuration correctly set to jre6
> directory, and used the default eclipse.ini adding only the -vm
> directory. I get the following error (and I agree with the person who
> said not being able to cut/paste was evil):
> Java was started but returned exit code-13
> C:\Program Files (x86)\java\jre6\bin\javaw.exe
> -Xms40m
> -Xmx484m
> -XX:MaxPermSize=356m
> -jar
> C:\eclipse\\plugin/org.eclipse.equinox.launcher_1.1.1.R63x)v20101122_1400.jar
> -os win32
> -ws win32
> -arch x86_64
> -showsplash
> -launcher C:\eclipse\eclipse.exe
> -name Eclipse
> --launcher.library
> C:\eclipse\\plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar
> -exitdata 17a8_58
> -vm C:\Program Files (x86)\java\jre6\bin\javaw.exe
> -vmargs
> -Xms40M
> -Xmx384m
> -XX:MaxPermSize=256m
> -jar
> Not sure if the problem is jre6, eclipse or windows 7 but this is a
> pretty vanilla installation so it should work right out of the box.
FUDForum. Page generated in 0.02975 seconds
