Home » Modeling » EMF » Best practice for changing EClass to abstract
Best practice for changing EClass to abstract [message #672299] Fri, 20 May 2011 15:43 Go to next message
h1055071 is currently offline h1055071Friend
My Ecore model has an EClass, DiagramModel. It's not abstract and is persisted to an XML file with the same name, "DiagramModel".
Now I want to make this class abstract and have a new class extending it called ArchimateDiagramModel. This new class replaces the functionality of the old DiagramModel class and I can extend DiagramModel with new classes.
But because I need to read the XML element "DiagramModel" from file and load in the new ArchimateDiagramModel class in place of the old one I have added to the ExtendedMetaData like this:
ExtendedMetaData ext = new BasicExtendedMetaData(........
ext.setName(IArchimatePackage.Literals.DIAGRAM_MODEL, "AbstractDiagramModel");
ext.setName(IArchimatePackage.Literals.ARCHIMATE_DIAGRAM_MODEL, "DiagramModel");
This means that the (now abstract) DiagramModel is given a new name and loading in an XML file loads the new ArchimateDiagramModel class whenever the element "DiagramModel" is encountered. Likewise when saving the model.
Ideally, though, I would like to save and load the ArchimateDiagramModel class with the tag "ArchimateDiagramModel" and only replace the "DiagramModel" with ArchimateDiagramModel class for backward compatibility. In other words:
1. ArchimateDiagramModel is persisted with "ArchimateDiagramModel" xml tag
2. If "DiagramModel" tag is encountered, load ArchimateDiagramModel class
Is this possible?
Many thanks,
Phil
Re: Best practice for changing EClass to abstract [message #672379 is a reply to message #672299] Fri, 20 May 2011 21:17 Go to previous messageGo to next message
I suppose the short question is this:
How do I get Ecore to load the class ArchimateDiagramModel instead of class DiagramModel when it de-serialises the xml element "DiagramModel", but write the xml element "ArchimateDiagramModel" when it serialises it?
Re: Best practice for changing EClass to abstract [message #674597 is a reply to message #672299] Fri, 27 May 2011 13:50 Go to previous message
In the end I did this in my ResourceFactory:
            ExtendedMetaData ext = new BasicExtendedMetaData(ExtendedMetaData.ANNOTATION_URI,
                    EPackage.Registry.INSTANCE, new HashMap<EModelElement, EAnnotation>()) {
                public EClassifier getType(EPackage ePackage, String name) {
                     * Backwards compatibility for the old "DiagramModel" type
                    if("DiagramModel".equals(name)) {
                        return IArchimatePackage.Literals.ARCHIMATE_DIAGRAM_MODEL;
                    return super.getType(ePackage, name);
It works.
Re: Best practice for changing EClass to abstract [message #686825 is a reply to message #672299] Fri, 20 May 2011 15:48 Go to previous message
Philip,
Comments below.
Phillip Beauvoir wrote:
> "DiagramModel");
> saving the model.
> tag
> Is this possible?
You could use the extended meta data option only for loading...
> Many thanks,
> Phil
Re: Best practice for changing EClass to abstract [message #686829 is a reply to message #672379] Fri, 20 May 2011 23:32 Go to previous message
Phillip,
That's why I suggested using what you have for loading (it maps the
"old" name to the new name) and given that it's created the
ArchimateDiagramModelImpl, when you serialize after that, with no
special options, it will use ArchimateDiagramModel. Right?
> it serialises it?
Re: Best practice for changing EClass to abstract [message #687012 is a reply to message #672379] Fri, 20 May 2011 23:32 Go to previous message
Phillip,
> it serialises it?
Previous Topic:(no subject)
Next Topic:(no subject)
Current Time: Sat Jun 06 02:59:54 GMT 2020
Powered by FUDForum. Page generated in 0.01546 seconds
