XML Datasource multiple call problem [Partly Resolved] [message #672188] |
Fri, 20 May 2011 08:46 |
Cyril Rognon Messages: 24 Registered: July 2010 |
Hi birt power users,
I have been using Birt for some time now and I have been using xml datasource with success.
Lately I have made the usage of runtime parametrized xml datasource : I provide the url of the datasource as a parameter to the report.
Halas, I have juste realizaed that my datasource is call many times durind the rendering or the report.
I have 2 datasets on one XML Datasource retrieved through one url http//server/path-to-xml-source-file
I have tried to inline one http/XML datasource url and to remove my scripting to set FILELIST beforeOpen but it did not erase the multiple call.
Why would the http call appear more htan once ? (4 times in may case)
thx
Cyril
[Updated on: Wed, 25 May 2011 11:43] Report message to a moderator
Re: XML Datasource multiple call problem [message #672278 is a reply to message #672188] |
Fri, 20 May 2011 13:52 |
What version of BIRT are you using?
Jason
> thx
> Cyril
Re: XML Datasource multiple call problem [message #673731 is a reply to message #673626] |
Tue, 24 May 2011 15:01 |
First the XML data source is used in two data sets, so at least there
will be two URL hits.
Currently xml datasources are not cached. If you are using aggregates
you will have multiple passes over the xml file resulting in additional
calls.
As a work around do you have the option to make the xml local? Or you
could load a byte array input stream in the before open script. Take a
look at the attached example.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.20"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.1.v20090903 Build <2.5.1.v20090917-1447></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 <<Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">auto layout</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.datatools.enablement.oda.xml" name="Data
Source" id="6">
<method name="beforeOpen"><![CDATA[importPackage(
Packages.java.io );
var mystr = "<?xml version=\"1.0\"?>";
mystr = mystr + "<library>";
mystr = mystr + "<book category=\"COOKINGgg\">";
mystr = mystr + "<title lang=\"en\">The test2 Cook Book</title>";
mystr = mystr + "<author name=\"Miguel Ortiz\" country=\"es\"/>";
mystr = mystr + "<sold>10,312</sold>";
mystr = mystr + "<year>2005</year>";
mystr = mystr + "</book>";
mystr = mystr + "<book category=\"CHILDREN\">";
mystr = mystr + "<title lang=\"en\">Everyone is Super Special</title>";
mystr = mystr + "<author name=\"Sally Bush\" country=\"uk\"/>";
mystr = mystr + "<sold>8,222</sold>";
mystr = mystr + "<book category=\"AUTOBIOGRAPHY\">";
mystr = mystr + "<title lang=\"en\">Japanese Greetings</title>";
mystr = mystr + "<author name=\"Taro Yamada\" country=\"uk\"/>";
mystr = mystr + "<sold>7,852</sold>";
mystr = mystr + "<book category=\"WEB\">";
mystr = mystr + "<title lang=\"en\">Query Kick End</title>";
mystr = mystr + "<author name=\"James McGovern\" country=\"us\"/>";
mystr = mystr + "<sold>15,111</sold>";
mystr = mystr + "<year>2006</year>";
mystr = mystr + "<audio format=\"CD\" category=\"MUSIC\">";
mystr = mystr + "<title lang=\"en\">Feels Like Home</title>";
mystr = mystr + "<artist name=\"Norah Jones\" country=\"us\"/>";
mystr = mystr + "<sold>9,675</sold>";
mystr = mystr + "</audio>";
mystr = mystr +"</library>";
JavaStr = new java.lang.String( mystr );
bais = new ByteArrayInputStream( JavaStr.getBytes());
appcon = reportContext.getAppContext();
//apcontext setting
appcon.put("org.eclipse.datatools.enablement.oda.xml.inputStream", bais);
//change file location
//this.setExtensionProperty("FILELIST",
"C:\\test\\xmldatasource.xml");]]></method>
<property name="FILELIST">C:\test\xmldatasource.xml</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.datatools.enablement.oda.xml.dataSet"
name="Data Set" id="7">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">category</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">title</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">name</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">sold</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">year</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">category</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">title</property>
</structure>
<structure>
<property name="nativeName">name</property>
</structure>
<structure>
<property name="nativeName">sold</property>
</structure>
<structure>
<property name="nativeName">year</property>
</structure>
</list-property>
<xml-property
name="queryText"><![CDATA[table0#-TNAME-#table0#:#[/library/book]#:#{category;STRING;/@category},{title;STRING;/title},{name;STRING;/author/@name},{sold;STRING;/sold},{year;STRING;/year}]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>category</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>-1</design:precision>
<design:scale>-1</design:scale>
<design:nullability>Unknown</design:nullability>
</design:attributes>
<design:usageHints>
<design:label>category</design:label>
<design:formattingHints/>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>title</design:name>
<design:position>2</design:position>
<design:usageHints>
<design:label>title</design:label>
<design:attributes>
<design:name>name</design:name>
<design:position>3</design:position>
<design:usageHints>
<design:label>name</design:label>
<design:attributes>
<design:name>sold</design:name>
<design:position>4</design:position>
<design:usageHints>
<design:label>sold</design:label>
<design:attributes>
<design:name>year</design:name>
<design:position>5</design:position>
<design:usageHints>
<design:label>year</design:label>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
<list-property name="privateDriverProperties">
<ex-property>
<name>MAX_ROW</name>
<value>-1</value>
</ex-property>
<ex-property>
<name>XML_FILE</name>
</ex-property>
</list-property>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
<style name="detail" id="42">
<property name="backgroundColor">#BACAE2</property>
<property name="fontFamily">"Arial"</property>
<property name="fontSize">small</property>
<property name="paddingTop">0px</property>
<property name="paddingLeft">0px</property>
<property name="paddingBottom">0px</property>
<property name="paddingRight">0px</property>
</style>
<style name="headerfooter" id="43">
<property name="backgroundColor">#004080</property>
<property name="fontWeight">bold</property>
<property name="color">#FFFFFF</property>
</style>
<style name="groupheader" id="44">
<property name="backgroundColor">#0080FF</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">1in</property>
<property name="leftMargin">1.25in</property>
<property name="bottomMargin">1in</property>
<property name="rightMargin">1.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<grid id="49">
<property name="borderBottomColor">#004080</property>
<property name="borderBottomWidth">medium</property>
<property name="borderLeftColor">#004080</property>
<property name="borderLeftWidth">medium</property>
<property name="borderRightColor">#004080</property>
<property name="borderRightWidth">medium</property>
<property name="borderTopColor">#004080</property>
<property name="borderTopWidth">medium</property>
<property name="width">7in</property>
<column id="50"/>
<row id="51">
<cell id="52">
<extended-item extensionName="Chart" name="mychart"
id="48">
<xml-property
name="xmlRepresentation"><![CDATA[<model:ChartWithAxes
xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute"
xmlns:data="http://www.birt.eclipse.org/ChartModelData"
xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout"
xmlns:model="http://www.birt.eclipse.org/ChartModel"
xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Type>Bar Chart</Type>
<SubType>Side-by-side</SubType>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<Visible>true</Visible>
<Label>
<Caption>
<Value>Bar Chart Title</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
<horizontalAlignment>Center</horizontalAlignment>
<verticalAlignment>Center</verticalAlignment>
</Alignment>
</Font>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<HorizontalSpacing>5</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Position>Right</Position>
<ItemType>Categories</ItemType>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Above</TitlePosition>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>509.99999999759996</Width>
<Height>309.00000000240004</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
</Block>
<Dimension>Two_Dimensional</Dimension>
<Units>Points</Units>
<SeriesThickness>10.0</SeriesThickness>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>A, B, C</DataSetRepresentation>
</BaseSampleData>
<OrthogonalSampleData>
<DataSetRepresentation>5,4,12</DataSetRepresentation>
<SeriesDefinitionIndex>0</SeriesDefinitionIndex>
</OrthogonalSampleData>
</SampleData>
<Interactivity/>
<EmptyMessage>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</EmptyMessage>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Value>X-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Below</TitlePosition>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>Y-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>90.0</Rotation>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Left</TitlePosition>
<SeriesDefinitions>
<Query>
<Definition></Definition>
</Query>
<SeriesPalette>
<Entries xsi:type="attribute:ColorDefinition">
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series xsi:type="type:BarSeries">
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["sold"]</Definition>
</DataDefinition>
<SeriesIdentifier></SeriesIdentifier>
<DataPoint>
<Components>
<Type>Orthogonal_Value</Type>
</Components>
<Separator>, </Separator>
</DataPoint>
<LabelPosition>Outside</LabelPosition>
<Stacked>false</Stacked>
<Riser>Rectangle</Riser>
</Series>
<Grouping>
<Enabled>false</Enabled>
<GroupingInterval>2.0</GroupingInterval>
<GroupType>Text</GroupType>
<AggregateExpression>Sum</AggregateExpression>
</Grouping>
<Sorting>Ascending</Sorting>
</SeriesDefinitions>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Left</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickStyle>Across</TickStyle>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
<MinorGridsPerUnit>5</MinorGridsPerUnit>
</Scale>
<Origin>
<Type>Min</Type>
<Value xsi:type="data:NumberDataElement">
<Value>0.0</Value>
</Value>
</Origin>
<PrimaryAxis>true</PrimaryAxis>
<Percent>false</Percent>
</AssociatedAxes>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
Re: XML Datasource multiple call problem [message #674034 is a reply to message #673981] |
Wed, 25 May 2011 15:38 |
Can you try something like the following:
In the beforeFactory of the report put code in like:
importPackage(Packages.java.lang);
importPackage(Packages.java.net);
importPackage(Packages.java.io);
var url = new URL("http://localhost:8090/book/BookStore.xml");
connection = url.openConnection();
inp = connection.getInputStream();
contentLength = connection.getContentLength();
bytesa = new ByteArrayOutputStream( contentLength);
var c;
while((c=inp.read()) != -1){
bytesa.write(c);
inp.close();
var mybytes = bytesa.toByteArray();
bais = new ByteArrayInputStream( mybytes );
Then in the beforeOpen of each of the datasets enter something like:
bais.reset();
reportContext.getAppContext().put("org.eclipse.datatools.enablement.oda.xml.inputStream",
bais);
Jason
On 5/25/2011 7:33 AM, Cyril Rognon wrote:
> Hi again,
> I have used your script and some basic java urlconnection stuff :
> importPackage(Packages.java.io );
> importPackage(Packages.java.net );
> //url setup from parameter values
> url = new URL(params["source_uri"]+params["reference"]);
> // GET HTTP connection = url.openConnection();
> is = connection.getInputStream();
> //apcontext setting
> appcon.put("org.eclipse.datatools.enablement.oda.xml.inputStream", is);
> it works. I now have only 2 access to the datasource URL.
> Now I'll have to look into the ODA code to see why the Datasource is
> called for each Dataset.
> Thx for your Help Jason, I managed to get this far thanks to you !
> My best
> Cyril
Re: XML Datasource multiple call problem [message #929848 is a reply to message #674034] |
Mon, 01 October 2012 20:40 |
John J Feigal Messages: 31 Registered: July 2009 |
Member |
For a couple of years, my organization has faced this issue that Cyril reported, but I wasn't able to describe it as well as Cyril did.
Jason Weatherby's comment that XML data is not cached finally explained why we were seeing the multiple http traces of the XML data access. I'm assuming that in Birt 3.7.2 that XML data still is not cached.
I have tried to implement Jason's final code suggestion, but I have been running into errors when I run my test report in debug mode.
I have tried a couple of things.
First, in the report's beforeFactory, I have tried to put an input stream in the report's appContext and then get the inputstream from the reports appContext in the dataset's beforeOpen. Jason's original code example showed a reset on the inputStream in the beforeOpen, but I was getting an error indicating the the named inputStream was undefined.
Alterntively, in the report's beforeFactory, I have gried to set a persistent global variable in the report context with the input stream, and then get the input stream from the persistent global variable in the reportContext in the dataset's beforeOpen. I'm getting an error that the method setPersistentGlobalVariable cannot be found in the beforeFactory and the inputStream is undefined in the beforeOpen.
Re: XML Datasource multiple call problem [message #931121 is a reply to message #930885] |
Tue, 02 October 2012 23:59 |
I believe the issue is that ByteArrayInputStream is not serializable, but in this case you really do not need this call. Drop the var keyword on the following line in the beforeFactory:
var demographicOneInputStream = new ByteArrayInputStream( mybytesOne );
to
//makes it global to downstream process
delete setPersistent line
Then just delete this line in the beforeOpen
var demographicOneInputStream = reportContext.getPersistentGlobalVariable( "demographicOneInputStream" );
Alternatively you could use set and getGlobalVariable instead.
Jason
Re: XML Datasource multiple call problem [message #932977 is a reply to message #932099] |
Thu, 04 October 2012 16:19 |
John
var is often best to use, but dropping it does make the variable global to downstream report items. That said a better approach is probably to use the setGlobalVariable as there is no ambiguity in this approach. Persisted global variables are used to write the variable back into the generated rptdocument, and allows the variable to be used at render time. This is often required when using onrender scripts or when you want to pass a generation variable to the chart script(executed at render time not generation).
On your new issue:
Did you set:
bais);
Jason
Re: XML Datasource multiple call problem [message #937311 is a reply to message #934256] |
Mon, 08 October 2012 22:03 |
Are you sure the xml structure is the same for the byte array as it is in the xml file you designed the report with? Save the bytearray to a file and compare them:
//add this after you read everything into the byte arrray
outputStream = new FileOutputStream ("c:/temp/test.xml");
byteArrayOutputStream.writeTo(outputStream);
Jason
Re: XML Datasource multiple call problem [message #938336 is a reply to message #938261] |
Tue, 09 October 2012 19:35 |
Member |
Jason
Here's the beforeFactory script after making the changes you suggested:
var urlOne = new URL( encodeURI( params["dbUrl"] ) + "agtDereferenceXmlViewDataForDocumentCountReportNew?OpenAgent&viewName=vwExportCustomerProfileDataByDocidXml_customerProfile" + "&beginDate=" + params["beginDate"] + "&endDate=" + params["endDate"] + "&dataFieldName=" + params["demographicOne"] + "&dataColumn=1&derefKeywords=true&debug=false&rowCount=1000" );
connectionOne = urlOne.openConnection();
inpOne = connectionOne.getInputStream();
contentLengthOne = connectionOne.getContentLength();
demographicOneInputStream = new ByteArrayOutputStream( contentLengthOne );
var cOne;
while((cOne = inpOne.read()) != -1)
demographicOneInputStream.write( cOne );
inpOne.close();
appcon.put("org.eclipse.datatools.enablement.oda.xml.inputStream", demographicOneInputStream );
var urlTwo = new URL( params["dbUrl"] + "agtDereferenceXmlViewDataForDocumentCountReportNew?OpenAgent&viewName=vwExportCustomerProfileDataByDocidXml_customerProfile" + "&beginDate=" + params["beginDate"] + "&endDate=" + params["endDate"] + "&dataFieldName=" + params["demographicTwo"] + "&dataColumn=1&derefKeywords=true&debug=false&rowCount=1000" );
connectionTwo = urlTwo.openConnection();
inpTwo = connectionTwo.getInputStream();
contentLengthTwo = connectionTwo.getContentLength();
demographicTwoInputStream = new ByteArrayOutputStream( contentLengthTwo );
var cTwo;
while((cTwo = inpTwo.read()) != -1)
demographicTwoInputStream.write(cTwo);
inpTwo.close();
appcon.put("org.eclipse.datatools.enablement.oda.xml.inputStream", demographicTwoInputStream );
I removed the lines of code that created a ByteArrayInputStream from a toByteArray:
mybytesOne = bytesaOne.toByteArray();
and
mybytesTwo = bytesaTwo.toByteArray();
demographicTwoInputStream = new ByteArrayInputStream( mybytesTwo );
demographicOneInputStream and demographicTwoInputStream are now created from the streams that created the XML files in the temp folder which I have verified are good.
I am confused, though, why you told me to remove the beforeOpen script code. When I ran the report, it ran successfully, but the data came from my default XML file, not from the streams that were put into the appcontext in the beforeFactory script. How is the dataset supposed to know how to get the XML data from the input streams?
Earlier in this thread, long long ago, you suggested to Cyril to use the toByteArray / ByteArrayInputStream code to save the "dynamic" XML data from the "dynamic" XML data source in memory so that it was only read once. When I used this code I received the XML parse error - premature end of file. When I try to use the input stream data that I have proved is correctly read and saved in temp files, incorrect data is reported.
I hope there is some obvious explanation for what is now happening. If not, I will place the original version of this report in production with the known performance issues, since our production software publish is tomorrow afternoon.
Thanks again for your help with this problem, but I do have to ask, will open source BIRT ever cache XML data which seems like the solution for the issue experienced by Cyril and myself (and possibly others)?
Re: XML Datasource multiple call problem [message #939806 is a reply to message #938336] |
Thu, 11 October 2012 04:06 |
John
Sorry for the confusion. It has to be an input stream.
Go back to this code (note that none of the code is in the beforeOpen. This should be ok because the inputstream is in the appcontext, which the xml driver should read):
bytesaOne = new ByteArrayOutputStream( contentLengthOne );
var cOne;
bytesaOne.write( cOne );
inpOne.close();
demographicOneInputStream.reset();
reportContext.getAppContext().put( "org.eclipse.datatools.enablement.oda.xml.inputStream", demographicOneInputStream );
Any chance I can run and debug your report?
BTW in 3.7.2 > finer cache control was added but I do not know it will help here.
http://www.eclipse.org/birt/phoenix/project/notable4.2.php#jump_11
Jason
FUDForum. Page generated in 0.04678 seconds
