Re: Fonts in PDF Report [message #672267 is a reply to message #672156] |
Fri, 20 May 2011 13:31 |
You did not need to remove the other paths. Are you getting anything in
the log file?
Jason
On 5/20/2011 1:58 AM, Maria K. wrote:
> More information:
> The folder containing the fontsConfig.xml file is the following:
> org.eclipse.birt.report.engine.fonts_2.5.1.v20090821
Re: Fonts in PDF Report [message #682196 is a reply to message #682050] |
Fri, 10 June 2011 15:20 |
Maria,
I just tested this with 2.6.2 and it worked fine. I downloaded a ttf
font put it in a directory on my c driver and then added a path to it at
the top of the font-paths tag in the fontsConfig.xml. The report ran
and used the font. I removed the font path and it the report reverted
to the default font.
<font-paths>
<path path="C:/work/styles/BaroqueScript" />
<path path="C:/windows/fonts" />
<path path="d:/windows/fonts" />
<path path="e:/windows/fonts" />
<path path="f:/windows/fonts" />
<path path="g:/windows/fonts" />
<path path="C:/WINNT/fonts" />
<path path="d:/WINNT/fonts" />
Jason
On 6/10/2011 5:55 AM, Maria K. wrote:
> Yes.. I'm getting the following exception:
> Caused by: java.lang.NullPointerException: Failed to create Times-Roman
> which is not allow
> at
> org.eclipse.birt.report.engine.layout.pdf.font.FontHandler.getMappedFont(FontHandler.java:244)
> at
> org.eclipse.birt.report.engine.layout.pdf.font.FontHandler.selectFont(FontHandler.java:162)
> at
> org.eclipse.birt.report.engine.layout.pdf.font.FontSplitter.buildChunk(FontSplitter.java:82)
> at
> org.eclipse.birt.report.engine.layout.pdf.font.FontSplitter.getNext(FontSplitter.java:173)
> at
> org.eclipse.birt.report.engine.layout.pdf.text.ChunkGenerator.getNext(ChunkGenerator.java:104)
> at
> org.eclipse.birt.report.engine.nLayout.area.impl.TextCompositor.getNextTextArea(TextCompositor.java:146)
> at
> org.eclipse.birt.report.engine.nLayout.area.impl.TextCompositor.getNextArea(TextCompositor.java:109)
> at
> org.eclipse.birt.report.engine.nLayout.area.impl.TextAreaLayout.layoutChildren(TextAreaLayout.java:181)
> at
> org.eclipse.birt.report.engine.nLayout.area.impl.TextAreaLayout.layout(TextAreaLayout.java:172)
> at
> org.eclipse.birt.report.engine.nLayout.area.impl.BlockTextArea.layout(BlockTextArea.java:68)
> at
> org.eclipse.birt.report.engine.nLayout.LayoutEngine.startContent(LayoutEngine.java:459)
> at
> org.eclipse.birt.report.engine.emitter.ContentEmitterAdapter.startText(ContentEmitterAdapter.java:147)
> at
> org.eclipse.birt.report.engine.emitter.ContentEmitterAdapter.startLabel(ContentEmitterAdapter.java:153)
> at
> org.eclipse.birt.report.engine.emitter.CompositeContentEmitter.startLabel(CompositeContentEmitter.java:282)
> at
> org.eclipse.birt.report.engine.emitter.ContentEmitterUtil.startContent(ContentEmitterUtil.java:65)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLTableLayoutEmitter.startContent(HTMLTableLayoutEmitter.java:146)
> at
> at
> at
> at
> org.eclipse.birt.report.engine.layout.html.buffer.HTMLPageBuffer.startContent(HTMLPageBuffer.java:116)
> at
> org.eclipse.birt.report.engine.layout.html.buffer.TableBreakBuffer.startContent(TableBreakBuffer.java:286)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLLeafItemLM.start(HTMLLeafItemLM.java:67)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:136)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:137)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.resumeLayout(HTMLInlineStackingLM.java:111)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.layoutNodes(HTMLInlineStackingLM.java:160)
> at
> at
> at
> at
> at
> org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.layoutChildren(HTMLTableBandLM.java:67)
> at
> at
> at
> at
> org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layoutChildren(HTMLTableLM.java:132)
> at
> at
> at
> org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:90)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:99)
> at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:170)
> ... 83 more
> Why is not possible to have a true type font of my choice, for PDF
> Rendering? (I have successfully created PDFs in any font I wanted, using
> directly itext).
Re: Fonts in PDF Report [message #683204 is a reply to message #682196] |
Mon, 13 June 2011 08:16 |
Maria K. Messages: 4 Registered: May 2011 |
Thx Jason !
a question though:
you added the following path, first in the <font-paths> tag:
Is there a reason that you didn't write <path path="C:/work/styles/BaroqueScript.ttf" /> ??
Should the extension be omitted?
I suppose BaroqueScript is not mentioned anywhere else in the fontsConfig.xml file.
Did you register this font in Windows, before using it?
[Updated on: Mon, 13 June 2011 08:17] Report message to a moderator
Re: Fonts in PDF Report [message #683309 is a reply to message #683204] |
Mon, 13 June 2011 13:39 |
My BaroqueScript.ttf was located in this directory:
C:/work/styles/BaroqueScript/BaroqueScript.ttf
The config file can use search directories. When I downloaded this font
I copied it to my windows fonts directory designed a report that used
it, then shut down the designer, deleted the font from the windows
directory and put it in the above directory. I modified the fonts
config as shown in previous post and ran the report in my deployed env.
Jason
On 6/13/2011 4:16 AM, Maria K. wrote:
> Thx Jason !
> a question though:
> Is there a reason that you didn't write "<path
> fontsConfig.xml file. Did you register this font in Windows, before
> using it?
Re: Fonts in PDF Report [message #740268 is a reply to message #683309] |
Tue, 18 October 2011 10:26 |
harip kaligo Messages: 74 Registered: July 2011 |
Member |
I have a similar issue with PDF fonts. We are using birt3.7. It works fine in windows, but when deployed in linux we are getting Times New roman as default.
What settings need to be done, to make the pdf use Arial.
In linux, we do not have any fonts installed.
Any help regarding this is appreciated.
Thanks.
Hari Priya
[Updated on: Tue, 18 October 2011 10:30] Report message to a moderator
FUDForum. Page generated in 0.03052 seconds
