Re: EEF 1.0 missing EEF extension feature [message #674309 is a reply to message #672015] |
Thu, 26 May 2011 13:23 |
Originally posted by:
Hi Nathalie,
the EEF extended runtime is used to generates richtext widgets and has a
dependency with EPF that does not provide any p2 repo. we disabled the
contribution in Indigo, but you can try it by downloading the epf
directly from www.eclipse.org/epf and installing it manually.
then you will be able to install EEF 1.0.0 SDK with extended
capabilities using your favorite way.
Le 19/05/2011 17:13, Nathalie a écrit :
> Hello,
> I am in the process to update to the EEF 1.0 version. The problem is it
> is missing a feature that I am extensively using for my custom EEF
> editor design.
> The feature in question is org.eclipse.emf.eef.extended.feature.group. I
> can see it in the release of 0.9 though.
> Is it going to be permanently removed in future versions?
> Thank you.
Stéphane Bouchet, OBEO
FUDForum. Page generated in 0.03245 seconds
