(no subject) [message #671662 is a reply to message #671615] |
Wed, 18 May 2011 15:05 |
Colin,
The inner data set has a binding tab, which has a data set parameters
button that allows the inner dataset's query parameters to be linked to
the outer data row. Is this what you want?
Jason
On 5/18/2011 9:40 AM, Colin Sutton wrote:
> I have been trying to display data from one data set that is
> referenced in another data set. I followed the subreport
> example, but that only allows tables to be linked. My inner
> data set needs a parameter supplied from a table in the
> outer data set.
> I tried using a hyperlink, passing data from a row in the
> outer table via a parameter to a query in the linked
> report, but I don't see a way to display that data inside the outer
> table, only in the whole window. Is there a way
> to do it?
(no subject) [message #671988 is a reply to message #671970] |
Thu, 19 May 2011 14:08 |
Colin,
The binding tab is on the table when it is placed in the report.
Can you post your report?
Jason
On 5/19/2011 8:57 AM, Colin wrote:
> I don't see a binding tab on the data set. The binding tab is on the array;
> my parameters are used in the beforeOpen script of the data set and do not
> appear in the table's data set parameter dialog.
> Colin
> Jason Weathersby<jasonweathersby@windstream.net> wrote:
>> Colin,
>> Jason
>>> outer data set.
>>> to do it?
FUDForum. Page generated in 0.01781 seconds
