Re: Class diagram observations [message #672325 is a reply to message #671333] |
Fri, 20 May 2011 17:21 |
The property are completely regeenrated so normaly bugs that you have add has to be fixed.
But for this use case:
Quote:I created a new class in a blank diagram and dropped a couple of properties into the AttributeComnpartment so I have Property0, Property1 and Property2 in order.
As I said in an earlier post I cannot type in the Edit Label otherwise Eclipse locks up so I need to use the Property editor. So I left click on the class which bolds the outline and then right click to bring up the context menu and select "Show Properties View". Nothing happens. This might be expected since the Properties view is already displayed but if that is true, then the class properties should be displayed as soon as I select it. Now if I left click on the diagram background, the class properties are displayed. Since I cannot find any documentation, I'm not exactly sure how this is supposed to work but the way it is now is not intuitive.
It seems that a service of papyrus is not launched. I have verified in my laptop with the last source code and it seems running now. I
FUDForum. Page generated in 0.03624 seconds
