Select via JPA (eclipselink) hangs on java.net.SocketInputStream.socketRead0(Native Method) [message #671258] |
Tue, 17 May 2011 10:05 |
Sirdeaz Messages: 7 Registered: May 2011 |
Junior Member |
I've created an application which uses an executor to fetch data. At random times the application tends to stop from working. After the needed debugging (using jconsole) I found out that the threads hang on java.net.SocketInputStream.socketRead0(Native Method). I'm executing regular database fetches/selects, there are no updates involved. The data that is fetched is based on a view containing database links.
I've set up a <property name="javax.persistence.query.timeout" value="10"/> in the persistence.xml file. But it seems to be ignored (the behaviour reoccured after I set up the timeout). Threads weren't released after the 10s timeout.
It's a desktop app using:
- java: 1.6.0_18
- eclipselink: javax.persistence_2.0.1.v201006031150.jar
- oracle jdbc driver: ojdbc6.jar
- oracle db: oracle 11.1.0.7.0
I'm looking forward to your replies.
Frederik
[Updated on: Tue, 17 May 2011 10:46] Report message to a moderator
Re: Select via JPA (eclipselink) hangs on java.net.SocketInputStream.socketRead0(Native Method) [message #674204 is a reply to message #672565] |
Thu, 26 May 2011 06:46 |
Junior Member |
Full stack dumps as requested:
State: RUNNABLE
Total blocked: 2 Total waited: 84
Stack trace:
java.net.SocketInputStream.read(Unknown Source)
oracle.net.ns.Packet.receive(Packet.java:240)
oracle.net.ns.DataPacket.receive(DataPacket.java:92)
oracle.net.ns.NetInputStream.getNextPacket(NetInputStream.java:172)
oracle.net.ns.NetInputStream.read(NetInputStream.java:117)
oracle.net.ns.NetInputStream.read(NetInputStream.java:92)
oracle.net.ns.NetInputStream.read(NetInputStream.java:77)
oracle.jdbc.driver.T4CMAREngine.unmarshalUB1(T4CMAREngine.java:1034)
oracle.jdbc.driver.T4CMAREngine.unmarshalSB1(T4CMAREngine.java:1010)
oracle.jdbc.driver.T4C8Oall.receive(T4C8Oall.java:588)
oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:194)
oracle.jdbc.driver.T4CPreparedStatement.executeForDescribe(T4CPreparedStatement.java:791)
oracle.jdbc.driver.T4CPreparedStatement.executeMaybeDescribe(T4CPreparedStatement.java:866)
oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1178)
oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3387)
oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3431)
- locked oracle.jdbc.driver.T4CConnection@13cd468
oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuery(OraclePreparedStatementWrapper.java:1491)
org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeSelect(DatabaseAccessor.java:888)
org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:598)
org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:526)
org.eclipse.persistence.sessions.server.ServerSession.executeCall(ServerSession.java:529)
org.eclipse.persistence.internal.sessions.IsolatedClientSession.executeCall(IsolatedClientSession.java:133)
org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:206)
org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:192)
org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeSelectCall(DatasourceCallQueryMechanism.java:263)
org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.selectAllRows(DatasourceCallQueryMechanism.java:644)
org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectAllRowsFromTable(ExpressionQueryMechanism.java:2537)
org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectAllRows(ExpressionQueryMechanism.java:2496)
org.eclipse.persistence.queries.ReadAllQuery.executeObjectLevelReadQuery(ReadAllQuery.java:407)
org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:1074)
org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:736)
org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1034)
org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAllQuery.java:380)
org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1112)
org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2909)
org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1291)
org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1273)
org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1247)
org.eclipse.persistence.internal.jpa.EJBQueryImpl.executeReadQuery(EJBQueryImpl.java:479)
org.eclipse.persistence.internal.jpa.EJBQueryImpl.getResultList(EJBQueryImpl.java:714)
be.carglass.purchaseassistant.persistence.FutureJobData.findByArtCode(FutureJobData.java:126)
be.carglass.purchaseassistant.gui.IncomingJobChartPanel$1.call(IncomingJobChartPanel.java:132)
be.carglass.purchaseassistant.gui.IncomingJobChartPanel$1.call(IncomingJobChartPanel.java:86)
java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
java.util.concurrent.FutureTask.run(Unknown Source)
java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
java.lang.Thread.run(Unknown Source)
State: RUNNABLE
Total blocked: 2 Total waited: 83
Stack trace:
- locked oracle.jdbc.driver.T4CConnection@8da6f
This is an example of a possible stack trace. It appears to happen at random times. All queries are finetuned to run in less than 2 seconds, unless this behaviour occurs.
[Updated on: Thu, 26 May 2011 17:18] Report message to a moderator
FUDForum. Page generated in 0.03132 seconds
