Home » Modeling » M2T (model-to-text transformation) » Acceleo Remove Annotation Error (While using Imports tag in Acceleo)
Acceleo Remove Annotation Error [message #671093] Mon, 16 May 2011 18:21 Go to next message
When I am using imports tag to import other .mtl module, It throws error as shown in attached file.
Each time I make a simple editing in editor marker becomes active to indicate error , but if I clean the project each time it works fine.
Please have a look at attached images
  • Attachment: error.JPG
    (Size: 175.21KB, Downloaded 234 times)
  • Attachment: error1.JPG
    (Size: 185.63KB, Downloaded 239 times)
  • Attachment: dataTypeGen.JPG
    (Size: 198.96KB, Downloaded 200 times)
  • Attachment: workflow.JPG
    (Size: 171.70KB, Downloaded 214 times)
Re: Acceleo Remove Annotation Error [message #671249 is a reply to message #671093] Tue, 17 May 2011 09:27 Go to previous messageGo to next message
Hi Dharam,
The problem that you have is related to this bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=335761
It is a known issue in Acceleo 3.0.x and it has been fixed in Acceleo 3.1.0 which will be released next month.
I'll investigate the problem of the NullPointerException, but I think it was also fixed for 3.1.0
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Acceleo wiki: http://wiki.eclipse.org/Acceleo
Blogs: http://stephanebegaudeau.tumblr.com & http://sbegaudeau.tumblr.com
Re: Acceleo Remove Annotation Error [message #671254 is a reply to message #671249] Tue, 17 May 2011 09:41 Go to previous message
Ya Thanks a lot.
Previous Topic:[ACCELEO] Overwriting existing files?
Next Topic:[Xpand] Having trouble accessing signals from enclosing package
Current Time: Thu Feb 13 14:15:10 GMT 2025
Powered by FUDForum. Page generated in 0.04245 seconds
