Home » Modeling » Graphiti » connection to another connection
connection to another connection [message #671079] Mon, 16 May 2011 17:36 Go to next message
Matt Biehl is currently offline Matt BiehlFriend
Is it possible to create a special type of connection that can connect to another connection?
Attached is a picture that visualizes the desired scenario.
index.php/fa/2747/0/
  • Attachment: example.png
    (Size: 0.47KB, Downloaded 302 times)
[Updated on: Mon, 16 May 2011 17:37]
Report message to a moderator
Re: connection to another connection [message #671269 is a reply to message #671079] Tue, 17 May 2011 10:16 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
Graphiti supports to attach connections to other connections in its newest
version (0.8.0 for Eclipse Indigo, M7 available). What happens in fact is
that after attaching the other connection is split into two connections and
a shape is inserted for the connection (can also be just 1 px or invisible).
I'm not sure though if creating exactly the impression on the image you
attached is possible; the gap could be a problem.
For details on this new feature see
http://www.eclipse.org/graphiti/pages/whats-new.html, in section M6
"Connections on Connections".
Michael
"Matt Biehl" wrote in message news:iqrmrg$82l$1@news.eclipse.org...
Is it possible to create a apecial type of connection that
Re: connection to another connection [message #672321 is a reply to message #671269] Fri, 20 May 2011 16:54 Go to previous messageGo to next message
Works fine with 0.8 RC1 Smile
Thanks!
BTW: the example code is in the tests folder, not on the examples folder as described on the newsworthy webpage. The example code is here:
org.eclipse.gmp/org.eclipse.gmp.graphiti/tests/org.eclipse.graphiti.testtool.sketch
in there look for the class AbstractSketchCreateSimpleConnectionFeature
Re: connection to another connection [message #673644 is a reply to message #672321] Tue, 24 May 2011 10:18 Go to previous messageGo to next message
Thanks for pointing out. I updated the docu.
Michael
"Matt Biehl" wrote in message news:ir65re$nuc$1@news.eclipse.org...
Works fine with 0.8 RC1 :)
Thanks!
Re: connection to another connection [message #677369 is a reply to message #671079] Wed, 08 June 2011 10:19 Go to previous message
Filippo Rossoni is currently offline Filippo RossoniFriend
you can also create a connection decorator with a shape for example an ellipse,
add an anchor to ellipse. And connect connection to that anchor
Previous Topic:exception on thumbnail
Next Topic:Re: Image resize and rotate
Current Time: Thu Aug 13 07:02:03 GMT 2020
Powered by FUDForum. Page generated in 0.01922 seconds
