Remote Development again... [message #670235] |
Fri, 13 May 2011 07:49 |
Thomas . Messages: 32 Registered: July 2009 |
Member |
Since months I frequently tried to setup a somewhat special remote development IDE.
I already have asked questions in this forum, but unfortunately my knowledge still is not enough to achieve my goal...
How do I have to setup a project with C/C++, Java, Pascal and more languages in it?
The sources exist in one big source tree, which has to be accessed via a *local* ClearCase mount on my WinXP PC.
The software has to be build and run on remote machines.
Occasionally build host and run host differ, and always they are not my local WinXP PC.
The build uses make with handwritten makefiles, even for Java, and a set of targets which have to be called in correct sequence.
The target all is supported, but not used.
What kind of project do I have to use?
How to setup local source access, remote building and remote launching?
Even more:
Which project of Eclipse is responsible for remote building?
Which project of Eclipse is responsible for remote debugging?
Does this depend on the language? Why?
Help me please!
Re: Remote Development again... [message #674404 is a reply to message #673914] |
Thu, 26 May 2011 19:37 |
Corey Ashford Messages: 9 Registered: July 2009 |
Thomas wrote on Wed, 25 May 2011 03:17
When you look at my initial post in this thread, you may find *local* files + *remote* build + *remote* debug. I've tried to achieve this guided by the tutorials you have linked me to, but still I'm stuck...
I don't think that the particular flavor of partially local and partially remote development that you want to do is currently supported by any of the available mechanisms.
PTP's RDT+Remote Tools is particularly good at remote builds, but it's designed to access the source code *only* from the remote machine. Any changes you make are not made locally.
PTP's Synchronized Projects (available in Eclipse 3.7RCx) sounds a little closer to your environment, but the current plug-in utilizes Git for synchronization, and I don't know how well that would play with ClearCase. I suspect you'd get into a bad state very quickly with that solution.
[Updated on: Fri, 27 May 2011 21:34] Report message to a moderator
FUDForum. Page generated in 0.03642 seconds
