Home » Modeling » M2T (model-to-text transformation) » [ACCELEO] How to make Acceleo to use my model?
icon5.gif  [ACCELEO] How to make Acceleo to use my model? [message #669806] Wed, 11 May 2011 15:15 Go to next message
Harri T. is currently offline Harri T.Friend
I'm trying to follow the entity generation screncast at tinyurl.com/5rjnzzc (acceleo.org) but the problem is that java source files for my own sample UML classes are not generated. Instead only the following files are generated:
src/main/java/fr/obeo/sample/dao/SampleDaoFactory.java
src/main/resources/dao.properties
src/main/resources/hibernate.cfg.xml
src/main/resources/sample-contraints.sql
src/main/resources/sample-ddl.sql
src/test/java/fr/obeo/sample/dao/test/AllSampleDaoTests.java
Any idea? I'm using Topcased 4.3.0 and Acceleo 2.8.0 in Eclipse Helios SR2.
Harri
Re: [ACCELEO] How to make Acceleo to use my model? [message #669810 is a reply to message #669806] Wed, 11 May 2011 15:30 Go to previous messageGo to next message
Stephane Begaudeau is currently offline Stephane BegaudeauFriend
This forum is used for Acceleo 3.x, the forum dedicated to the old version of Acceleo (before the entrance of Acceleo in the Eclipse Foundation) can be found here
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Acceleo wiki: http://wiki.eclipse.org/Acceleo
Blogs: http://stephanebegaudeau.tumblr.com & http://sbegaudeau.tumblr.com
Re: [ACCELEO] How to make Acceleo to use my model? [message #669813 is a reply to message #669810] Wed, 11 May 2011 15:40 Go to previous messageGo to next message
Stephane Begaudeau wrote on Wed, 11 May 2011 11:30
Thanks for answering! Does Acceleo 3 provide sample templates for generating Java classes from UML model?
[Updated on: Wed, 11 May 2011 18:39]
Report message to a moderator
Re: [ACCELEO] How to make Acceleo to use my model? [message #669945 is a reply to message #669813] Thu, 12 May 2011 07:24 Go to previous messageGo to next message
Yes, you can find an example of UML to Java generation in Acceleo: File -> New -> Example -> Acceleo Model to Text -> UML to Java.
Or you can also find an UML to Java generator for Acceleo 3.1 (which will be released in 5/6 weeks) that I'm working on, here: https://github.com/ObeoNetwork/UML-Java-Generation
(this generator is for Acceleo 3.1 only because of some documentation block that are only available in 3.1, if you remove them, you can use it with Acceleo 3.0 while waiting for Acceleo 3.1 next month).
[Updated on: Thu, 12 May 2011 07:25]
Re: [ACCELEO] How to make Acceleo to use my model? [message #670295 is a reply to message #669945] Fri, 13 May 2011 12:21 Go to previous messageGo to next message
Stephane Begaudeau wrote on Thu, 12 May 2011 03:24
Thanks for helping! I found it and I'm going to add support for Hibernate annotations. Before that I should learn how to define stereotype for Hibernate entities. Have you got examples about it?
Great! Is 3.1 going to be released for Eclipse Helios or just for Indigo?
Harri
Re: [ACCELEO] How to make Acceleo to use my model? [message #670328 is a reply to message #670295] Fri, 13 May 2011 14:28 Go to previous messageGo to next message
I don't have any examples of this, sorry.
3.1 will be released with indigo but you can install it in eclipse 3.6 helios if you want.
Re: [ACCELEO] How to make Acceleo to use my model? [message #699349 is a reply to message #669806] Thu, 21 July 2011 12:10 Go to previous message
Daniel is currently offline DanielFriend
Hi Harri,
I have the same problem as you, how did you solve yours? although I am doing the exact same thing as in the screencasts.
Regards.
Previous Topic:[Acceleo] EEnum access from a module
Next Topic:[Acceleo] Does the Acceleo Language support constants?
Current Time: Mon Jun 14 21:46:33 GMT 2021
Powered by FUDForum. Page generated in 0.01648 seconds
