Re: Project from local bare repository [message #669535 is a reply to message #669454] |
Tue, 10 May 2011 15:49 |
Drew Decker Messages: 3 Registered: May 2011 |
Paul Webster wrote on Tue, 10 May 2011 07:48On 05/09/2011 06:55 PM, Drew Decker wrote:
> I have a local repository, which is a bare repository. I
> need to be able to do the same thing I can do in command
> line in egit (eclipse). via command line, I can clone the
> repository (bare) add files, etc, commit, and push the
> changes.
You would clone a repo in the Git Repositories view from the bare repo
(don't use Add Local Repo on the bare repo). Then when you create your
project, and instead of using the default location use a subdir of your
cloned repo.
From there, you are able to commit your changes and push them to the
bare repo.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
This worked perfectly thanks!
[Updated on: Tue, 10 May 2011 15:49] Report message to a moderator
FUDForum. Page generated in 0.03274 seconds
