Logging error in OSGI/Spring DM [message #669298] |
Mon, 09 May 2011 19:47 |
Christian A Messages: 13 Registered: March 2011 |
i try to migrate an existing spring application to osgi and spring dm.
When i start the application i get the stack-trace, listed below.
It seems that the osgi.extender can not create the applicationi context due to an error in the
logging configuration. I added the slf4j (version 1.5.11) plugins "org.slf4j.log4j", "org.slf4j.jcl" and "org.slf4j.api",
to use slf4j on top of log4j.
The log4j properties file is bundled in a fragment, that is assigned to the log4j plugin.
Obviously the osgi.extender tries to run the apache commons logger instead of slf4j.
What have i missed.
- is it necessary to start the logging bundles explicitly (via the config.ini) before the osgi.extender is startet?
- where do i place the log4j.properties file to make it accessible for the osgi.extender?
- is there any further configuration necessary, to get the log-system running?
Any help would be much appreciated.
osgi> 17:53:36.178 [Start Level Event Dispatcher] INFO o.s.o.e.i.a.ContextLoaderListener - Starting [org.springframework.osgi.extender] bundle v.[1.1.0]
17:53:36.189 [Start Level Event Dispatcher] DEBUG o.s.o.e.i.a.ContextLoaderListener - Spring-DM v.[1.1.0] is wired to Spring core bundle org.springframework.core version [2.5.6]
!SESSION 2011-05-09 17:53:29.956 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_24
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=de_DE
Command-line arguments: -dev file:/home/Entwicklung/eclipse_workspaces/test/.metadata/.plugins/org.eclipse.pde.core/Workbench/dev.properties -os linux -ws gtk -arch x86_64 -consoleLog -console -consolelog
!ENTRY org.springframework.osgi.extender 4 0 2011-05-09 17:53:36.205
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: Exception in org.springframework.osgi.extender.internal.activator.ContextLoaderListener.start() of bundle org.springframework.osgi.extender.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:806)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:370)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:374)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1067)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:561)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:546)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:459)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:440)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:337)
Caused by: java.lang.NoClassDefFoundError: org/apache/commons/logging/LogFactory
at org.springframework.osgi.io.internal.resolver.PackageAdminResolver.<clinit>(PackageAdminResolver.java:52)
at org.springframework.osgi.extender.internal.activator.SpringTypeCompatibilityChecker.<init>(SpringTypeCompatibilityChecker.java:49)
at org.springframework.osgi.extender.internal.activator.ContextLoaderListener.start(ContextLoaderListener.java:365)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
... 11 more
Caused by: java.lang.ClassNotFoundException: org.apache.commons.logging.LogFactory
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:506)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
... 17 more
Root exception:
at org.eclipse.osgi.framework.internal.core".AbstractBundle.resume(AbstractBundle.java:374)
... 17 more
17:53:36.218 [Start Level Event Dispatcher] INFO d.i.backend.internal.Activator - TEST => starting backend
!ENTRY org.eclipse.osgi 4 0 2011-05-09 17:53:36.223
!MESSAGE Bundle org.springframework.osgi.extender_1.1.0 [194] is not active.
[Updated on: Mon, 09 May 2011 19:49] Report message to a moderator
Re: Logging error in OSGI/Spring DM [message #669761 is a reply to message #669298] |
Wed, 11 May 2011 12:19 |
Martin Lippert Messages: 124 Registered: July 2009 |
Hi Christian!
I would recommend asking this question in the Virgo group. They are
better experts in Spring DM, I guess... :-)
-Martin
On 09.05.11 21:47, Christian A wrote:
> spring dm.
> below.
> "org.slf4j.api",
> What have i missed.
> log-system running?
> Thanks
> version [2.5.6]
> NL=de_DE
> file:/home/Entwicklung/eclipse_workspaces/test/.metadata/.pl ugins/org.eclipse.pde.core/Workbench/dev.properties
> -consolelog
> 17:53:36.205
> !MESSAGE
> !STACK 0
> org.springframework.osgi.extender.internal.activator.Context LoaderListener.start()
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:806)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:755)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:370)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:374)
> at
> org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1067)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:561)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:546)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:459)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:243)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:440)
> at
> org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:227)
> at
> org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:337)
> at
> org.springframework.osgi.io.internal.resolver.PackageAdminRe solver. <clinit>(PackageAdminResolver.java:52)
> at
> org.springframework.osgi.extender.internal.activator.SpringT ypeCompatibilityChecker. <init>(SpringTypeCompatibilityChecker.java:49)
> at
> org.springframework.osgi.extender.internal.activator.Context LoaderListener.start(ContextLoaderListener.java:365)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:783)
> at java.security.AccessController.doPrivileged(Native
> Method)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:774)
> ... 11 more
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:506)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:422)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:107)
> ... 17 more
> Root exception:
> at
> at
> at
> at
> Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 17 more
FUDForum. Page generated in 0.03414 seconds
