Re: Reports,Subreports and cell borders [message #668243 is a reply to message #668142] |
Wed, 04 May 2011 15:43 |
Chris
Can you reproduce this issue with the sample db? Use orders for the
outer and orderdetails for the inner.
If you can post the report.
Jason
On 5/4/2011 1:20 AM, Chris wrote:
> I have been trying to line up cell borders in a table and in a subreport
> which is a row in the table.
> Table has 2 detail rows Row 1 has 4 cells each of which has a border
> surrounding it.
> Row 2 has merged all 4 cells and contains the subreport table which
> consists of 4 cells with borders.
> The borders from the 1st row need to line up with the borders from
> subreport in the second row.
> I have tried setting padding to 0 in both tables and all cells and all
> rows.
> Setting the cell width to the same in both tables still does not line
> them up.
> Trying to line them up by eye is not working. My report is output to PDF.
> All help would be appreciated.
> Chris
Re: Reports,Subreports and cell borders [message #668522 is a reply to message #668243] |
Fri, 06 May 2011 04:09 |
Chris Messages: 47 Registered: September 2010 |
Member |
Thanks Jason,
I have created a quick report. To me it has 2 issues
1. there is a gap between the orders row and the detail rows.
2. The left and right sides of the columns do not line up exactly.
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.6.1.v20100902 Build <2.6.1.v20100915-1750></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source" id="7">
<list-property name="privateDriverProperties">
<ex-property>
<name>contentBidiFormatStr</name>
<value>ILYNN</value>
</ex-property>
<ex-property>
<name>metadataBidiFormatStr</name>
</ex-property>
</list-property>
<property name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="Orders" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property name="displayName">ORDERNUMBER</text-property>
<text-property name="heading">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">ORDERDATE</property>
<text-property name="displayName">ORDERDATE</text-property>
<text-property name="heading">ORDERDATE</text-property>
</structure>
<structure>
<property name="columnName">REQUIREDDATE</property>
<text-property name="displayName">REQUIREDDATE</text-property>
<text-property name="heading">REQUIREDDATE</text-property>
</structure>
<structure>
<property name="columnName">SHIPPEDDATE</property>
<text-property name="displayName">SHIPPEDDATE</text-property>
<text-property name="heading">SHIPPEDDATE</text-property>
</structure>
<structure>
<property name="columnName">COMMENTS</property>
<text-property name="displayName">COMMENTS</text-property>
<text-property name="heading">COMMENTS</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">ORDERDATE</property>
<property name="dataType">date</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">REQUIREDDATE</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">SHIPPEDDATE</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">COMMENTS</property>
<property name="dataType">string</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">ORDERDATE</property>
<property name="nativeDataType">91</property>
</structure>
<structure>
<property name="nativeName">REQUIREDDATE</property>
</structure>
<structure>
<property name="nativeName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="nativeName">COMMENTS</property>
<property name="nativeDataType">12</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select CLASSICMODELS.ORDERS.ORDERNUMBER
,CLASSICMODELS.ORDERS.ORDERDATE
,CLASSICMODELS.ORDERS.REQUIREDDATE
,CLASSICMODELS.ORDERS.SHIPPEDDATE
,CLASSICMODELS.ORDERS.COMMENTS
from CLASSICMODELS.ORDERS]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERDATE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>91</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>ORDERDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERDATE</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>REQUIREDDATE</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>REQUIREDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>REQUIREDDATE</design:label>
<design:attributes>
<design:name>SHIPPEDDATE</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>SHIPPEDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>SHIPPEDDATE</design:label>
<design:attributes>
<design:name>COMMENTS</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>32700</design:precision>
<design:uiHints>
<design:displayName>COMMENTS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COMMENTS</design:label>
<design:displaySize>32700</design:displaySize>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>
]]></xml-property>
</oda-data-set>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="OrderLines" id="9">
<structure>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property name="displayName">PRODUCTCODE</text-property>
<text-property name="heading">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property name="displayName">QUANTITYORDERED</text-property>
<text-property name="heading">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property name="displayName">PRICEEACH</text-property>
<text-property name="heading">PRICEEACH</text-property>
</structure>
</list-property>
<list-property name="parameters">
<structure>
<property name="name">porderno</property>
<property name="nativeName"></property>
<expression name="defaultValue" type="javascript">10100</expression>
<property name="isOptional">true</property>
<property name="allowNull">true</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
</list-property>
<structure>
</structure>
<structure>
<property name="name">PRODUCTCODE</property>
</structure>
<structure>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select CLASSICMODELS.ORDERDETAILS.ORDERNUMBER
,CLASSICMODELS.ORDERDETAILS.PRODUCTCODE
,CLASSICMODELS.ORDERDETAILS.QUANTITYORDERED
,CLASSICMODELS.ORDERDETAILS.PRICEEACH
from CLASSICMODELS.ORDERDETAILS
where CLASSICMODELS.ORDERDETAILS.ORDERNUMBER=?]]></xml-property>
<design:DataSetParameters>
<design:parameterDefinitions>
<design:inOutMode>In</design:inOutMode>
<design:attributes>
<design:name></design:name>
<design:inputAttributes>
<design:elementAttributes>
<design:optional>true</design:optional>
</design:elementAttributes>
</design:inputAttributes>
</design:parameterDefinitions>
</design:DataSetParameters>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:criteria/>
]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="10">
<property name="dataSet">Orders</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression" type="javascript">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["ORDERDATE"]</expression>
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["REQUIREDDATE"]</expression >
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["SHIPPEDDATE"]</expression >
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["COMMENTS"]</expression>
</structure>
</list-property>
<list-property name="sort">
<structure>
<expression name="key" type="javascript">row["ORDERNUMBER"]</expression>
<property name="direction">asc</property>
<property name="strength">-1</property>
</structure>
</list-property>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<column id="42"/>
<header>
<row id="11">
<cell id="12">
<label id="13">
<text-property name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="14">
<label id="15">
<text-property name="text">ORDERDATE</text-property>
</label>
</cell>
<cell id="16">
<label id="17">
<text-property name="text">REQUIREDDATE</text-property>
</label>
</cell>
<cell id="18">
<label id="19">
<text-property name="text">SHIPPEDDATE</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="22">
<cell id="23">
<property name="borderBottomColor">#000000</property>
<property name="borderBottomWidth">thin</property>
<property name="borderLeftColor">#000000</property>
<property name="borderLeftWidth">thin</property>
<property name="borderRightColor">#000000</property>
<property name="borderRightWidth">thin</property>
<property name="borderTopColor">#000000</property>
<property name="borderTopWidth">thin</property>
<property name="paddingTop">0pt</property>
<property name="paddingLeft">0pt</property>
<property name="paddingBottom">0pt</property>
<property name="paddingRight">0pt</property>
<data id="24">
<property name="whiteSpace">nowrap</property>
<property name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="25">
<data id="26">
<property name="resultSetColumn">ORDERDATE</property>
</data>
</cell>
<cell id="27">
<data id="28">
<property name="resultSetColumn">REQUIREDDATE</property>
</data>
</cell>
<cell id="29">
<data id="30">
<property name="resultSetColumn">SHIPPEDDATE</property>
</data>
</cell>
</row>
<row id="44">
<cell id="45">
<property name="colSpan">4</property>
<property name="rowSpan">1</property>
<table id="50">
<property name="dataSet">OrderLines</property>
<list-property name="paramBindings">
<structure>
<property name="paramName">porderno</property>
<simple-property-list name="expression">
<value type="javascript">row["ORDERNUMBER"]</value>
</simple-property-list>
</structure>
</list-property>
<structure>
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["PRICEEACH"]</expression>
</structure>
</list-property>
<structure>
</structure>
<structure>
<expression name="key" type="javascript">row["PRODUCTCODE"]</expression>
</structure>
</list-property>
<column id="74"/>
<column id="75"/>
<column id="76"/>
<column id="77"/>
<detail>
<row id="60">
<cell id="61">
<data id="62">
</data>
</cell>
<cell id="63">
<data id="64">
<property name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="65">
<data id="66">
<property name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="67">
<data id="68">
<property name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
</row>
</detail>
</table>
</cell>
</row>
</detail>
</table>
</body>
</report>
Re: Reports,Subreports and cell borders [message #668664 is a reply to message #668522] |
Fri, 06 May 2011 15:41 |
You still had 1 in the padding for the cell containing the detail row.
Take a look at the revised example.
Jason
id="1">
<data-sources>
<oda-data-source
id="7">
<ex-property>
</ex-property>
<ex-property>
</ex-property>
</list-property>
<property
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:criteria/>
</model:DesignValues>]]></xml-property>
</oda-data-set>
<oda-data-set
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<model:DesignValues
<design:attributes>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:criteria/>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<table id="10">
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
</list-property>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<column id="42"/>
<header>
<row id="11">
<cell id="12">
<property
<label id="13">
<text-property
</label>
</cell>
<cell id="14">
<property
<label id="15">
<text-property
</label>
</cell>
<cell id="16">
<property
<label id="17">
<text-property
</label>
</cell>
<cell id="18">
<property
<label id="19">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="22">
<cell id="23">
<property
<data id="24">
<property
</data>
</cell>
<cell id="25">
<property
<data id="26">
<property
</data>
</cell>
<cell id="27">
<property
<data id="28">
<property
</data>
</cell>
<cell id="29">
<property
<data id="30">
<property
</data>
</cell>
</row>
<row id="44">
<cell id="45">
<property name="textAlign">left</property>
<table id="50">
<structure>
<property
name="expression">
<value
</structure>
</list-property>
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
</list-property>
<structure>
<property
</structure>
<structure>
<property
</structure>
</list-property>
<column id="74"/>
<column id="75"/>
<column id="76"/>
<column id="77"/>
<detail>
<row id="60">
<cell id="61">
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<data id="62">
<property
<property
</data>
</cell>
<cell id="63">
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<data id="64">
<property
<property
</data>
</cell>
<cell id="65">
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<data id="66">
<property
<property
</data>
</cell>
<cell id="67">
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<data id="68">
<property
<property
</data>
</cell>
</row>
</detail>
</table>
</cell>
</row>
</detail>
</table>
</body>
</report>
On 5/6/2011 12:09 AM, Chris wrote:
> Thanks Jason,
> id="1">
> <data-sources>
> <ex-property>
> </ex-property>
> <ex-property>
> </ex-property>
> </list-property><
FUDForum. Page generated in 0.03263 seconds
