Re: Profile modification for a Class Diagram [message #672488 is a reply to message #668386] |
Sat, 21 May 2011 09:30 |
Sébastien Gérard Messages: 121 Registered: July 2009 |
Class diagram is not linked to the profile diagram. First of all, I assume you have two files (indeed two set of three files), respectivey:
1 (YourProfile.profile.uml, YourProfile.profile.notation, YourProfile.profile.di) and (YourModelExample.uml, YourModelExample.notation and YourModelExample.di). L'et's call those sets for short: YourProfile.profile.di and YourModelExample.di.
If you are making a modif on YourProfile.profile.di you need to redefine it. When you have done your modification, and when saving them, Papyrus will ask you if you want to redefine your profile. You have to do it. By the way, you should have close previously YourExampleModel.di. Then after having redefining the profile, you can open again your model, YourModelExample.di and then if you select the root model of your model in the model browser and have a look on the tab Profile in the property view, then you will see that your profil has been modified and need to be re apply. So, you can re apply and then it should work.
Best... Sébastien.
FUDForum. Page generated in 0.04098 seconds
