Home » Eclipse Projects » Virgo » Dependency Problem?(Work on Linux, not on Windows 7)
Dependency Problem? [message #667667] Sat, 30 April 2011 21:58 Go to next message
Tidus is currently offline TidusFriend
I have a problem with dependencies on my Web Application.
So, I made an Dynamic Web Application which uses bundles on virgo.
This application provides rest services thanks to Jersey. This services uses bundles on virgo.
This application works perfectly on Linux.
I tried to use it on Windows 7 with the same virgo server and the same .WAR (copy/past/clean/run)
I always get an error saying that it doesn't find a class from a bundle which is in virgo (repository/usr). There is no compile error.
If a comment the line which uses this bundle, no error.
Have you an idea about this problem? Did i forget a step?
[Updated on: Sat, 30 April 2011 22:05]
Report message to a moderator
Re: Dependency Problem? [message #667679 is a reply to message #667667] Sun, 01 May 2011 09:11 Go to previous messageGo to next message
I will give you an example:
import java.io.File;
import java.io.FileNotFoundException;
import java.io.FileOutputStream;
import java.io.IOException;
import java.net.URL;
import java.util.HashSet;
import java.util.Iterator;
import java.util.Properties;
import java.util.Set;
import javax.ws.rs.core.Application;
public class TestApplication extends Application {
	private Set<Class<?>> classes;
	private Set<Object> singletons;
	public TestApplication ()
		classes = new HashSet<Class<?>>();
		singletons = new HashSet<Object>();
		classes.add(Manager.class);
		singletons.add(new Manager());
		APlugin plug = new APlugin();
	public Set<Class<?>> getClasses() {
		return classes;
	public Set<Object> getSingletons() {
		return singletons;
import javax.ws.rs.GET;
import javax.ws.rs.PUT;
import javax.ws.rs.Path;
import javax.ws.rs.PathParam;
import javax.ws.rs.Produces;
import javax.ws.rs.core.MediaType;
@Path("test")
public class Manager {
	@GET
        @Path("/hello")
	@Produces(MediaType.TEXT_HTML)
	public String Test()
		return "Hello World!";
web.xml
<web-app xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://java.sun.com/xml/ns/javaee" xmlns:web="http://java.sun.com/xml/ns/javaee/web-app_2_5.xsd" xsi:schemaLocation="http://java.sun.com/xml/ns/javaee http://java.sun.com/xml/ns/javaee/web-app_2_5.xsd" id="WebApp_ID" version="2.5">
  <display-name>TestService</display-name>
  <welcome-file-list>
    <welcome-file>index.html</welcome-file>
    <welcome-file>index.htm</welcome-file>
    <welcome-file>index.jsp</welcome-file>
    <welcome-file>default.html</welcome-file>
    <welcome-file>default.htm</welcome-file>
    <welcome-file>default.jsp</welcome-file>
  </welcome-file-list>
  <servlet>
    <servlet-name>JerseyTest</servlet-name>
    <servlet-class>com.sun.jersey.spi.container.servlet.ServletContainer</servlet-class>
    <init-param>
      <param-name>javax.ws.rs.Application</param-name>
      <param-value>TestApplication </param-value>
    </init-param>
    <load-on-startup>1</load-on-startup>
  </servlet>
  <servlet-mapping>
    <url-pattern>/*</url-pattern>
  </servlet-mapping>
</web-app>
Work perfectly on Linux. On Windows, I get exception (tested on 3 computers):
javax.servlet.ServletException: Servlet.init() for servlet JerseyTest threw exception
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102)
org.eclipse.virgo.web.tomcat.ApplicationNameTrackingValve.in voke(ApplicationNameTrackingValve.java:29)
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogVa lve.java:555)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:298)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:857)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:588)
org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:489)
java.lang.Thread.run(Thread.java:662)
root cause
com.sun.jersey.api.container.ContainerException: The Application class TestApplication could not be instantiated
com.sun.jersey.server.impl.application.DeferredResourceConfi g$ApplicationHolder. <init>(DeferredResourceConfig.java:86)
com.sun.jersey.server.impl.application.DeferredResourceConfi g$ApplicationHolder. <init>(DeferredResourceConfig.java:78)
com.sun.jersey.server.impl.application.DeferredResourceConfi g.getApplication(DeferredResourceConfig.java:75)
com.sun.jersey.server.impl.application.WebApplicationImpl._i nitiate(WebApplicationImpl.java:1028)
com.sun.jersey.server.impl.application.WebApplicationImpl.ac cess$600(WebApplicationImpl.java:159)
com.sun.jersey.server.impl.application.WebApplicationImpl$12 .f(WebApplicationImpl.java:693)
com.sun.jersey.server.impl.application.WebApplicationImpl$12 .f(WebApplicationImpl.java:690)
com.sun.jersey.spi.inject.Errors.processWithErrors(Errors.ja va:193)
com.sun.jersey.server.impl.application.WebApplicationImpl.in itiate(WebApplicationImpl.java:690)
com.sun.jersey.server.impl.application.WebApplicationImpl.in itiate(WebApplicationImpl.java:685)
com.sun.jersey.spi.container.servlet.ServletContainer.initia te(ServletContainer.java:488)
com.sun.jersey.spi.container.servlet.ServletContainer$Intern alWebComponent.initiate(ServletContainer.java:318)
com.sun.jersey.spi.container.servlet.WebComponent.load(WebCo mponent.java:601)
com.sun.jersey.spi.container.servlet.WebComponent.init(WebCo mponent.java:208)
com.sun.jersey.spi.container.servlet.ServletContainer.init(S ervletContainer.java:373)
com.sun.jersey.spi.container.servlet.ServletContainer.init(S ervletContainer.java:556)
javax.servlet.GenericServlet.init(GenericServlet.java:212)
APlugin is an import-bundle from virgo.
If I comment this line, all is working on Windows. But I need this plugin.
What did i forget?
[Updated on: Sun, 01 May 2011 09:15]
Re: Dependency Problem? [message #667718 is a reply to message #667679] Sun, 01 May 2011 16:17 Go to previous messageGo to next message
Hristo Iliev is currently offline Hristo IlievFriend
When migrating from Linux/Unix to Windows the problems are usually caused by wrong path separators. Can you check that you have correct paths in all files?
It seems to me that in this snippet:
<init-param>
</init-param>
the param-value has additional whitespace before the closing tag: "TestApplication "
Re: Dependency Problem? [message #667731 is a reply to message #667718] Sun, 01 May 2011 19:44 Go to previous messageGo to next message
I checked all my files.
I don"t see any problem.
My fault when copy/past ^^
I tried something: I move my bundle call from TestApplication to my service Test.
Now I have no initialisation error.
I have a class not found error (I think initialisation was caused by not found error):
exception
javax.servlet.ServletException: java.lang.NoClassDefFoundError: org/eclipse/gmt/modisco/infra/browser/custom/core/CustomizationsCatalog
	com.sun.jersey.spi.container.servlet.WebComponent.service(WebComponent.java:418)
	com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:537)
	com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:699)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
root cause
	HelloService.hello(HelloService.java:19)
	sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
	java.lang.reflect.Method.invoke(Method.java:597)
	com.sun.jersey.server.impl.model.method.dispatch.AbstractResourceMethodDispatchProvider$TypeOutInvoker._dispatch(AbstractResourceMethodDispatchProvider.java:168)
	com.sun.jersey.server.impl.model.method.dispatch.ResourceJavaMethodDispatcher.dispatch(ResourceJavaMethodDispatcher.java:71)
	com.sun.jersey.server.impl.uri.rules.HttpMethodRule.accept(HttpMethodRule.java:280)
	com.sun.jersey.server.impl.uri.rules.RightHandPathRule.accept(RightHandPathRule.java:147)
	com.sun.jersey.server.impl.uri.rules.ResourceObjectRule.accept(ResourceObjectRule.java:100)
	com.sun.jersey.server.impl.uri.rules.RootResourceClassesRule.accept(RootResourceClassesRule.java:84)
	com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1341)
	com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1273)
	com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1223)
	com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1213)
	com.sun.jersey.spi.container.servlet.WebComponent.service(WebComponent.java:414)
APlugin plug = new APlugin() was just an example.
The real line is: CustomizationsCatalog catalog = new CustomizationsCatalog(); from Modisco Plugin.
But that works on Linux. Why?
[Updated on: Sun, 01 May 2011 19:45]
Re: Dependency Problem? [message #667777 is a reply to message #667731] Mon, 02 May 2011 07:49 Go to previous messageGo to next message
You have imports for "org.eclipse.gmt.modisco" packages right?
Re: Dependency Problem? [message #668176 is a reply to message #667667] Wed, 04 May 2011 10:46 Go to previous message
Yes. No compilation problem and full working on Linux.
[Updated on: Wed, 04 May 2011 10:47]
Previous Topic:server.profile incomplete
Next Topic:snaps session sharing
Current Time: Mon Apr 12 20:33:09 GMT 2021
Powered by FUDForum. Page generated in 0.01610 seconds
