Re: JScrollPane problem in VE [message #668080 is a reply to message #667335] |
Tue, 03 May 2011 16:25 |
Yves YANG Messages: 688 Registered: July 2009 |
I'd like you know VE is in maintenance stage since 2008. Insight of a new
coming WindowBuilder, this project will be archived. I recommand you to
switch on WindowsBuilder if it is possible. If you insists on the support of
VE, please contact me directly.
Best regards
Yves YANG
"Ulf" <het_post_punkt_com@hotmail.com> wrote in message
news:ipb6e3$lju$1@news.eclipse.org...
> I have a JFrame VE dialog with a JList.
> I need to fill the list after in has been initialized so I create the
> JList with a DefaultListModel object in the constructor.
> Then i add elements to the DefaultListModel object. The elements are
> displayed in the list, BUT no vertical scrollbar appears so the lowest
> part of the elements are invisible.
> I have tried lots of settings in the methods of the JList and JScrollPane
> classes
> but the damn scrollbar refuses to appear!
> Here is my current code in the method that initializes the JList:
> * This method initializes itemList * * @return javax.swing.JList */
> private JList getItemList() {
> listModel = new DefaultListModel();
> if (itemList == null) {
> itemList = new JList(listModel);
> itemList.setBounds(new Rectangle(27, 83, 274, 242));
> itemList.setLayoutOrientation(JList.VERTICAL);
> itemList.setVisibleRowCount(-1);
> listScroller = new JScrollPane();
> listScroller.setViewportView(itemList);
> listScroller.setVerticalScrollBarPolicy(JScrollPane.VERTICAL
> _SCROLLBAR_ALWAYS);
> listScroller.setBounds(new Rectangle(27, 83, 274, 242));
> // TEMP TEST:
> listModel.addElement("foo bar foo bar 1");
> listModel.addElement("foo bar foo bar 2");
> listModel.addElement("foo bar foo bar 3");
> listModel.addElement("foo bar foo bar 50"); itemList.revalidate();
> return itemList;
> If anybody could tell how to get the vertical scrollbar in the JList
> then I would be very grateful and happy!
> Thanks in advance!
> SilentMajority
Re: JScrollPane problem in VE [message #668087 is a reply to message #668080] |
Tue, 03 May 2011 17:18 |
Ulf Messages: 2 Registered: April 2011 |
Hi Yves!
Thank you for the tip about WindowsBuilder. I am checking it out and it seems really cool!
However, if there is an easy solution to my scrollbar problem in VE I would be very glad to know about it, since I would need to deliver my GUI soon. I also have the same problem with missing scrollbars in a JTextArea.
If you know anyting about how to solve this in VE I would be very grateful.
You said I could contact you directly, but how do I find your mail address? I could not see it in your profile.
If you have time you could contact me on:
(het_post_punkt_com *at* hotmail.com)
Thanks in advance!
Ulf
SilentMajority
[Updated on: Tue, 03 May 2011 17:20] Report message to a moderator
FUDForum. Page generated in 0.03009 seconds
