Strange result in query [message #667299] |
Wed, 27 April 2011 21:54  |
I have tried the following recursive query (it traverses up a chain of
Package objects, to compute the full name):
[query public packageFullName(pack : Package, suffix : String) : String =
if pack.oclIsUndefined() then suffix else
packageFullName(pack._package, pack.name + '.' + suffix) endif
If called on a chain of packages with names org.eclipse.tests it returns
<undefined-object>.org.eclipse where <undefined-object> is the result of
calling oclUndefined.toString(). It is as if the pack.name expression in
pack.name + '.' + suffix is interpreted as pack._package.name.
However, the following works:
if pack.oclIsUndefined() then suffix else let suffix : String =
pack.name + '.' + suffix in packageFullName(pack._package, suffix) endif
I.e. the argument is computed before the recursive call to
packageFullName. I cannot understand why the result should differ and be
wrong in the first case.
Hallvard
Re: Strange result in query [message #667790 is a reply to message #667299] |
Mon, 02 May 2011 09:02   |
Hi Hallvard,
Seems to me like a variable leak in Acceleo. Could you raise a bug against M2T/Acceleo for this?
As for what you are trying to achieve ... Wouldn't it be easier with something like :
[ancestors(Package)->reverse().name->sep('.')/]
i.e "retrieve all ancestors of type "Package", reverse the list so that the root is first in the list, get all their names, then separate these names with dots". This is what we usually use when computing qualified names.
Laurent Goubet
Obeo
Re: Strange result in query [message #667805 is a reply to message #667790] |
Mon, 02 May 2011 09:44   |
> https://bugs.eclipse.org/bugs/enter_bug.cgi?product=M2T& component=Acceleo for
> this?
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=344424
> something like :
I didn't know about the ancestors function, thanks! However, the root
package is not the root of the model, so I think this would give me an
extra element that I need to remove (before or after doing reverse, I
guess).
Ideally, there is I would like to use a function that traverses along a
named relation (not necessarily the ancestor chain), 'package' in my
case, and collects them until it is null/empty. Does such a function
exist? Can I perhaps use OCL iterate construct?
Hallvard
Re: Strange result in query [message #667806 is a reply to message #667805] |
Mon, 02 May 2011 09:48   |
>> for
>> this?
>> something like :
> guess).
Sorry, I didn't notice the Package (oclType) argument, which filters out
non-Package object. Thanks for the tip!
Hallvard
Re: Strange result in query [message #667809 is a reply to message #667806] |
Mon, 02 May 2011 10:07   |
>>> for
>>> this?
>>> something like :
>> guess).
Update: ancestors(Package)->reverse().name gives an error marker. I
think it's because reverse isn't recognized, since
ancestors(Package).name works. BTW, I'm using Acceleo 3.0.2 with Helios.
Hallvard
Re: Strange result in query [message #667818 is a reply to message #667299] |
Mon, 02 May 2011 10:32   |
Hallvard,
I know we've fixed a number of bugs with both the "reverse" and "ancestors" services ... but I don't remember which . The 3.1.0 M7 build for Acceleo will be available tomorrow, and it should fix the issue you have with this query.
In the meantime, and if memory serves, you should be able to use this query instead :
[ancestors(Package)->asSequence()->reverse().name->sep('.')/]
As I seem to remember something about "ancestors" not being statically typed to a Sequence or OrderedSet (i.e. an ordered collection) and thus "reverse" not being applicable.
If that doesn't fix it, could you provide me with the message associated with this compilation error?
Laurent Goubet
Obeo
Re: Strange result in query [message #667836 is a reply to message #667818] |
Mon, 02 May 2011 12:09   |
This does not work, either.
The error marker's message is "Unrecognized variable: (name)". As I
said, ancestors(Package).name->sep('.') works fine, so I think the
problem is that reverse() is missing.
Hallvard
Re: Strange result in query [message #667884 is a reply to message #667299] |
Mon, 02 May 2011 15:12   |
ha, that one . It has been fixed too. The problem was that "reverse" lost the typing of the collection, ancestors(Package) returns a Collection(Package) but "Collection(Package)->reverse()" returns a Collection(T) ... and "name" does not exist on "T".
You can work around this by manually re-casting :
[ancestors(Package)->reverse().oclAsType(Package).name->sep('.')/]
These problems are fixed in Acceleo 3.1.
Laurent Goubet
Obeo
Re: Strange result in query [message #667935 is a reply to message #667884] |
Mon, 02 May 2011 20:07   |
On 02.05.11 17.12, Laurent Goubet wrote:
> ha, that one :p. It has been fixed too. The problem was that "reverse"
I understand. I can imagine it is a bit tricky to get everything correct.
When you use -> it is a method on the collection (object), right. While
when you use . it applies to every element in the collection? So
..oclAsType(Package) means the same as ->oclAsType(Sequence(Package))
(not sure if that's correct ocl, but you understand what I mean)?
Which is coming to a place near you, soon :-)
Hallvard
Re: Strange result in query [message #667971 is a reply to message #667935] |
Tue, 03 May 2011 07:39  |
Yup, though "oclAsType" cannot be used on a Collection (with a "->") AFAIK.
The M7 will be available today on the Milestones update site.
Laurent Goubet
Obeo
FUDForum. Page generated in 0.06812 seconds
