Problem to deploy many bundles in order from eclipse IDE [message #667269] |
Wed, 27 April 2011 18:27 |
Hi all,
Our situation is the following, we have an application that uses Spring MVC, Spring dm, Maven and we started few weeks ago to use Virgo (before of that we where using the Equinox incorporated with Eclipse). It has many bundles and most of them have dependencies to others.
We try to deploy from Eclipse IDE all the bundles together but it crashed for not respect the dependencies. So we must to deploy one by one, to respect the bundle dependencies.
For accelerate the application development we want to create a plan which deploy all the bundles directly from Eclipse IDE and that uses the workspace proyects to deploy in the Virgo server. The problem is that it looks for the bundles compiled in the repository forlder of the VWS and not realize that are in the workspace. So we want to know if there is any option to do that.
We are using Eclipse Helios, Spring DM Server tools plugin v2.6 and Virgo 2.1.1.RELEASE.
Thanks in advance,
Facundo
Re: Problem to deploy many bundles in order from eclipse IDE [message #667392 is a reply to message #667319] |
Thu, 28 April 2011 13:39 |
Hi Glyn,
Thanks for your reply. I tried to do what you said but Eclipse doesn't give me an option to create a plan, just bundles and pars, so as the virgo documentation says I create a faceted proyect with an Eclipse RT plan facet and when I finish the creation an error pop up araise saying that
" Problems encountered while setting project description.
Nature com.springsource.server.ide.facet.core.plannature is missing prerequisite nature: org.springframework.ide.eclipse.core.springnature."
The only way I had to create a plan was creating a common java project and I create inside it an xml file with the plan definition (with extension .plan). Virgo recognize the plan I allow me to deploy it but it don't find the bundles from my workspace. If I put the compiled bundles in the repository folder of virgo server, it works, but it's a bit anoying.
Any tip to solve that will be appreciated!
Facundo
Re: Problem to deploy many bundles in order from eclipse IDE [message #667448 is a reply to message #667408] |
Thu, 28 April 2011 19:43 |
Glyn,
Thanks men!
It works with drag & drop! Anyway I think there is something that don't work properly because we have to deploy two times the same plan deploy correctly. The first time we deploy the plan it still arraise an error because the server can't locate the bundles but we can see the bundles are deployed in stage area. When we undeploy and deploy the plan for second time it works fine.
Another problem what we had was that adding the plan from the option "Add and Remove..." of the server instance allways throws an error to find the bundles, cause it look for them in the repository and not in the workspace! A bit strange!
Thanks a lot,
Cheers
FUDForum. Page generated in 0.03194 seconds
