Home » Archived » B3 » How generate a p2 and maven repo?
How generate a p2 and maven repo? [message #667009] |
Mon, 25 April 2011 13:46  |
I want to generate a maven repository from the Texo/Teneo update site during the build process. The update site is
created during the build and at the end of the build I want to use b3 to generate a new site from the initial generated
update site.
I want the update site to only contain the Texo features and no dependencies, is this possible or how can I do that?
To test this I started by creating a b3 xml (see below), when I do build repository (from the ui), 3 directories are
created p2, interim and final, the p2 only contains these folders:
org.eclipse.equinox.p2.core
org.eclipse.equinox.p2.engine
org.eclipse.equinox.p2.repository
and the final directory only contains artifact.jar and contents.jar.
So I miss the final p2 site/maven repository. Am I doing something wrong?
Here is the b3 aggr file:
<aggregator:Aggregator xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:aggregator="http://www.eclipse.org/b3/2010/aggregator/1.0.0" buildmaster="//@contacts[email='mtaal@elver.org']"
label="Texo p2 and Maven repository" buildRoot="${user.home}/mytmp/test" mavenResult="true">
<configurations enabled="false"/>
<configurations enabled="false" operatingSystem="linux" windowSystem="gtk"/>
<contributions description="Texo" label="Texo" contacts="//@contacts[email='mtaal@elver.org']">
<repositories location=" http://download.eclipse.org/modeling/emft/texo/updates/inter im" description="Texo Update
Site"/>
</contributions>
<contributions label="Helios 3.6">
<repositories location="http://download.eclipse.org/releases/helios"/>
</contributions>
<contributions label="Texo Dependencies" contacts="//@contacts[email='mtaal@elver.org']">
<repositories location="http://www.elver.org/eclipse/update"/>
</contributions>
<contacts name="Martin Taal" email="mtaal@elver.org"/>
</aggregator:Aggregator>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: How generate a p2 and maven repo? [message #667808 is a reply to message #667009] |
Mon, 02 May 2011 09:58   |
Filip Hrbek Messages: 233 Registered: July 2009 |
Hi Martin,
I am sorry for answering so late, first I had been too busy and then I forgot about this issue.
I think that the main problem is that both your configurations are marked as disabled:
If you open the model in the editor, they are displayed as grey. Use context menu or EMF property view to enable one or both of them and try again.
Let me know if it helps. Keep in mind that mirroring the whole Eclipse repository may take a while though.
Filip
Dne 25.4.2011 15:46, Martin Taal napsal(a):
> I want to generate a maven repository from the Texo/Teneo update site during the build process. The update site is created during the build and at the end of the build I want to use b3 to generate a new site from the initial generated update site.
> To test this I started by creating a b3 xml (see below), when I do build repository (from the ui), 3 directories are created p2, interim and final, the p2 only contains these folders:
> <aggregator:Aggregator xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:aggregator="http://www.eclipse.org/b3/2010/aggregator/1.0.0" buildmaster="//@contacts[email='mtaal@elver.org']" label="Texo p2 and Maven repository" buildRoot="${user.home}/mytmp/test" mavenResult="true">
> <repositories location=" http://download.eclipse.org/modeling/emft/texo/updates/inter im" description="Texo Update Site"/>
> </contributions>
> </contributions>
> </contributions>
Re: How generate a p2 and maven repo? [message #668110 is a reply to message #667808] |
Tue, 03 May 2011 18:32   |
Hi Filip,
No problem at all, clear, I want to create a maven repository for specific texo features which only depend on emf. I
have created the xb3.aggr file but I am not sure how to prevent the whole helios from being seen as a contribution to.
So the texo repository should be the driver and only the emf jars should be pulled from the helios repository. How do I
define this?
<configurations operatingSystem="linux" windowSystem="gtk"/>
<repositories location=" http://download.eclipse.org/modeling/emft/texo/updates/inter im" description="Texo Update Site">
<features name="org.eclipse.emf.texo.runtime.core.feature.group"/>
<features name="org.eclipse.emf.texo.runtime.core.source.feature.group "/>
</repositories>
</contributions>
</contributions>
gr. Martin
On 05/02/2011 11:58 AM, Filip Hrbek wrote:
> Hi Martin,
> Regards
> Filip
>> Hi,
>> <?xml version="1.0" encoding="UTF-8"?>
>> </contributions>
>> </contributions>
>> </contributions>
The Netherlands
(no subject) [message #668771 is a reply to message #668110] |
Sat, 07 May 2011 09:16  |
Hi Martin,
you need to add an explicit mapping of org.eclipse.emf.* bundles that you require. Only explicitly mapped bundles and their dependencies (direct or transitive) will be collected to create the final repo.
I created an example that adds org.eclipse.emf.ecore as the explcit bundle from Helios (pasted below).
Is it what you need?
Filip
<configurations/>
</contributions>
<repositories location="http://download.eclipse.org/releases/helios">
<bundles name="org.eclipse.emf.ecore" versionRange="2.6.1.v20100914-1218"/>
</repositories>
</contributions>
</contributions>
Dne 3.5.2011 20:32, Martin Taal napsal(a):
> Hi Filip,
> No problem at all, clear, I want to create a maven repository for specific texo features which only depend on emf. I have created the xb3.aggr file but I am not sure how to prevent the whole helios from being seen as a contribution to. So the texo repository should be the driver and only the emf jars should be pulled from the helios repository. How do I define this?
> </repositories>
> </contributions>
> </contributions>
> gr. Martin
>> Hi Martin,
>> Regards
>> Filip
>>> Hi,
>>> </contributions>
>>> </contributions>
>>> </contributions>
Current Time: Wed Oct 04 18:09:20 GMT 2023
Powered by FUDForum. Page generated in 0.02303 seconds
