Re: Java Compile problem [message #666453 is a reply to message #666439] |
Wed, 20 April 2011 13:34 |
On 2011.04.20 7:28, Guy wrote:
> Hello all, I'm trying to learn how to use eclipse. I've installed the
> Europa version along with the IBM Java SDK. I've written a Java
> application via the Eclipse editor
> and now I want to compile it. I;ve created a project. Eclipse can "see"
> the path to the javac compiler, but I'm unable to get my program
> compiled, I have build automatic set ON
> I've tried the RUN button, and every other combination.
> I keep getting messages such as "unable to launch"
> (what ever that means) ..no previous launches
> there's another message about missing "pages" (I think)
> any suggestions would be most appreciated.
> Thanks
> GUy
If you're just starting out, why not install modern Eclipse. Europa was
followed by Ganymeade, Galileo and Helios. Indigo is about to be
released. Europa works, but most of the community is eager to support
much later releases in this forum.
Second, use only a Sun JDK unless there's some reason you must use another.
I'd suggest taking a look at
http://www.javahotchocolate.com/tutorials/eclipse-summary.ht ml, then
doing a couple of tutorials athttp://www.vogella.de/eclipse.htm
And come back here when you get stuck.
Best of luck.
FUDForum. Page generated in 0.09949 seconds
