Home » Eclipse Projects » Plugin Development Environment (PDE) » How to set default compiler compliance level inside plugin
How to set default compiler compliance level inside plugin [message #666385] Wed, 20 April 2011 09:29 Go to next message
Sergei  is currently offline Sergei Friend
I develop eclipse plugin and I need to set default compiler compliance level to 1.5 inside plugin.
As I know there is a org.eclipse.jdt.core.prefs file with such preference.
How can I change this preference using API level?
[Updated on: Wed, 20 April 2011 11:58]
Report message to a moderator
Re: How to set default compiler compliance level inside plugin [message #666414 is a reply to message #666385] Wed, 20 April 2011 11:18 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
Is it that you want to do it programmatically? Normally in PDE you set
it in the MANIFEST.MF:
Bundle-RequiredExecutionEnvironment: J2SE-1.5
And then if necessary right click on the project and use PDE
Tools>Update Classpath
Later,
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: How to set default compiler compliance level inside plugin [message #666417 is a reply to message #666414] Wed, 20 April 2011 12:01 Go to previous message
Thank you!
I've found solution:
Hashtable options = JavaCore.getDefaultOptions();
JavaCore.setComplianceOptions(JavaCore.VERSION_1_5, options);
JavaCore.setOptions(options);
[Updated on: Wed, 20 April 2011 12:01]
Previous Topic:Including jar from Plugin
Next Topic:create contextual menu in eclipse
Current Time: Wed Jul 28 12:05:57 GMT 2021
Powered by FUDForum. Page generated in 0.02140 seconds
