Home » Modeling » M2T (model-to-text transformation) » [Acceleo3] using ecore in query
[Acceleo3] using ecore in query [message #666374] Wed, 20 April 2011 08:24 Go to next message
Wilbert Alberts is currently offline Wilbert AlbertsFriend
I created a meta model and am experimenting with code generation.
In this, I have a PG_Return meta class that either might occur inside a PG_Calc or a PG_GetCalc object. The generated code depends on the context PG_Return is used in. Therefore, I created a query that checks whether the context of the PG_Return instance is within PG_GetCalc.
[query public inGetCalcContext(s: PG_Statement) : Boolean =
let container: EObject = s.eContainer()
in
	if (container <> null) and (container.oclIsTypeOf(PG_GetCalc))
	then
		true
	else
	    if (container = null)
	    then
	    	false
	    else
	    	inGetCalcContext(container)
	    endif
	endif
However, Acceleo complains that it doesn't know EObject? Is it not possible to use ecore concepts like above?
Greetings,
Wilbert
Re: [Acceleo3] using ecore in query [message #666667 is a reply to message #666374] Thu, 21 April 2011 13:55 Go to previous messageGo to next message
Stephane Begaudeau is currently offline Stephane BegaudeauFriend
Hi Wilbert,
If you want to use Ecore, you have to declare it in the header of your module:
[module generate('http://www.myawesomemetamodel.com', 'http://www.eclipse.org/emf/2002/Ecore')]
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Acceleo wiki: http://wiki.eclipse.org/Acceleo
Blogs: http://stephanebegaudeau.tumblr.com & http://sbegaudeau.tumblr.com
Re: [Acceleo3] using ecore in query [message #666673 is a reply to message #666667] Thu, 21 April 2011 14:08 Go to previous message
Hi Stephane ,
Again your answer was right to the spot for which I thank you.
However, in the documentation I stumbled across the 'Acceleo non standard operations reference'. The thing I wanted to achieve can also be solved using the 'ancestors' operation. Let's use as much as possible the provided operations.
Wilbert.
Previous Topic:Problem with using annotations in acceleo
Next Topic:[Acceleo] Generate a complex inheritance list
Current Time: Fri Mar 01 23:35:12 GMT 2024
Powered by FUDForum. Page generated in 0.02593 seconds
