Home » Language IDEs » ServerTools (WTP) » Rhino debugging in Helios - What am I missing?
Rhino debugging in Helios - What am I missing? [message #665709] Fri, 15 April 2011 15:00 Go to next message
Jim Garrison is currently offline Jim GarrisonFriend
Member
I have searched the web for several hours and cannot find a couple of key pieces of information that would let me use JSDT in Helios. I've seen all the pages describing how to set things up but am not able to actually get my Javascript to launch. Here's what I've done
I have launched the Rhino DebugShell in a command window as
java -cp "c:/dev/tools/rhino/js.jar;org.eclipse.wst.jsdt.debug.rhino.debugger_1.0.1.v201008170101.jar" org.eclipse.wst.jsdt.debug.rhino.debugger.shell.DebugShell -port 9000 -suspend y -trace true
I have launched the Rhino debug connector in Eclipse 3.6 SR2.
What I can't find is how to launch my Javascript in the debug shell. I tried passing its full path on the command line but that did nothing.
Can someone point me to where this is described?
Also, I can't seem to find a way to terminate the DebugShell other than killing the process with Task Manager.
Re: Rhino debugging in Helios - What am I missing? [message #665758 is a reply to message #665709] Fri, 15 April 2011 18:45 Go to previous messageGo to next message
Member
I got past the issues described above. I'd like to delete this post but there doesn't seem to be a "delete" option.
Re: Rhino debugging in Helios - What am I missing? [message #665893 is a reply to message #665758] Mon, 18 April 2011 04:26 Go to previous messageGo to next message
Syamkumar Cheedela is currently offline Syamkumar CheedelaFriend
Instead provide the resolution steps.
Re: Rhino debugging in Helios - What am I missing? [message #879913 is a reply to message #665709] Fri, 01 June 2012 05:36 Go to previous message
abc 33887 is currently offline abc 33887Friend
I have the same issue. Can you please provide your solution?
Previous Topic:XML multipage editor cutomization (GEF, design and source)
Next Topic:Cannot edit html files with Web Page Editor - HTML Editor
Current Time: Wed Oct 21 15:50:48 GMT 2020
Powered by FUDForum. Page generated in 0.02172 seconds
