Home » Newcomers » Newcomers » how to configure eclipse UI settings?(UI too fat on ubuntu)
how to configure eclipse UI settings? [message #665707] Fri, 15 April 2011 14:50 Go to next message
Jim  is currently offline Jim Friend
I just installed eclipse on a ubuntu machine, but the user interface looks very fat - that is, even though I set the system fonts to be small, the eclipse UI still leaves a lot of padding rooms around the fonts and wastes a lot of valuable screen property that could've been used for displaying lines of code. I looked around preferences, but didn't find where I can specify this. Is it possible to make the UI on ubuntu as slim as it is on windows?
please see the enclosed image for a comparison between ubuntu and windows
thanks!
https://lh6.googleusercontent.com/_JB-q3NzPG6c/TaRwcAzFWNI/AAAAAAAAACs/ZxyOOIzZBNA/fatUI.jpg
Re: how to configure eclipse UI settings? [message #1697760 is a reply to message #665707] Mon, 08 June 2015 08:51 Go to previous message
Aleksander   is currently offline Aleksander Friend
Member
Is there any way to change this? I've tried some custom themes, played around with the CSS files in the plugin folder but with no luck.
Thank you.
Previous Topic:project directly on live server
Next Topic:Hard time obfuscating java android code...
Current Time: Sun Jan 19 18:19:02 GMT 2020
Powered by FUDForum. Page generated in 0.04903 seconds
