Different test results when running headless SWTBot [message #665610] |
Fri, 15 April 2011 09:22 |
nester Messages: 1 Registered: March 2011 |
I have a problem with the reported tests results when running them headless. The test that should be reported as failed are reported as errors when running them headless. The same tests are correctly reported when run directly form Eclipse.
For example this assertion is shown as an error:
assertTrue(" Test should be failed ", false);
This is reported:
test2 Error Test should be failed :
java.lang.AssertionError: Test should be failed:
at com.btc.swtbottests.TestWizard.test2(TestWizard.java:72)
at org.eclipse.swtbot.swt.finder.junit.SWTBotJunit4ClassRunner. run(SWTBotJunit4ClassRunner.java:54)
at org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner .run(EclipseTestRunner.java:350)
at org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner .run(EclipseTestRunner.java:208)
at org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication .runTests(UITestApplication.java:116)
at org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:71)
So practicably assertions cause tests to be Error not Failed when running them headless, when running from Eclipse the same test are correctly reported .
I can't figure out why.
[Updated on: Fri, 15 April 2011 09:28] Report message to a moderator
FUDForum. Page generated in 0.03019 seconds
