"create new" from palette or diagram does not work in generatet diagram [message #665578] |
Fri, 15 April 2011 07:10 |
Originally posted by: Robin.Brandstaedter.gmx.de
hi,
i've got a problem, i generated two editors by using the gmf-dashboard.
The first one works fine, but if i use the second one, something does
not work, this is very confusing for me. I tryed it a lot of time from
the beginning, but the same failure appears every time. If i want to
create a new node from palette or diagram nothing happens, i also
started the editor in debug mode and discovered that the
createNodeFigure-methods are not called, there should be a notiyfication
fired and this notification should triggers all needed actions to create
and display the node in the diagram, it seems to me that this is not
done. Has anybody an idea about solving this problem or can does anybody
knows where my faults are located during the creation-steps?
kind regards Robin
FUDForum. Page generated in 0.01798 seconds
