[Epsilon] Standalone [message #665490] |
Thu, 14 April 2011 19:19 |
I downloaded the standalone example form the repository in order ti make my own implementation. I was creating a new class using the EpsilonStandaloneExample as a base/example. However, when I create a new calss and start to add the code, I get the following error in various lines, for example in:
module = createModule();
module.parse(getFile(getSource()));
The Error:
Access restriction: The method parse(File) from the type IModule is not accessible due to restriction on required library C:\Users\asistente\eclipse\hiles3.6\plugins\org.eclipse.epsilon.commons_0.9.0.201011251259\org.eclipse.epsilon.commons.jar
How can avoid this error from poping? I am missing some license information or similar in order to be able to inlcude epsilon classes in my own java project?
Thanks in advance,
Horacio
Horacio Hoyos Rodriguez
Kinori Tech
Need professional support for Epsilon, EMF?
Go to: https://kinori.tech
Re: [Epsilon] Standalone [message #665829 is a reply to message #665715] |
Sat, 16 April 2011 16:33 |
Hi Dimitris,
It is not a runtime exception, is an error that shows in the editor while writing the code (compilation error). I have the latest version of the plugin in the stable update site and using Eclipse 3.6 (Helios).
Horacio
Kinori Tech
Re: [Epsilon] Standalone [message #665838 is a reply to message #665490] |
Sat, 16 April 2011 21:10 |
Here are my findings on how I resolve it, though I don't know if this is a good solution.
I decided to take a look at the Build Path and Manifest f the EpsilonStandAloneProject. The Build Path showed me that there where some differences in the plugins imported (my project had more of the epsilon plugins). So I went and take a look at the manifest and found that as I wrote the code and solved the missing imports, the eclipse jars where added as "Imports" (single jars, not plugins):
Import-Package: org.eclipse.epsilon.commons.parse,
org.eclipse.epsilon.commons.parse.problem,
org.eclipse.epsilon.commons.util,
org.eclipse.epsilon.emc.emf,
org.eclipse.epsilon.eol,
org.eclipse.epsilon.eol.exceptions,
org.eclipse.epsilon.eol.exceptions.models,
org.eclipse.epsilon.eol.execute.context,
org.eclipse.epsilon.eol.models
However, in the EpsilonStandalone example Manifest, the plugins where added as "required bundles":
Require-Bundle: org.eclipse.epsilon.eol.engine,
org.eclipse.epsilon.ecl.engine,
org.eclipse.epsilon.egl.engine,
org.eclipse.epsilon.eml.engine,
org.eclipse.epsilon.erl.engine,
org.eclipse.epsilon.etl.engine,
org.eclipse.epsilon.evl.engine,
org.eclipse.epsilon.ewl.engine,
org.eclipse.uml2.uml
I changed my Manifest to the Epsilon example form and the error was gone.
I am not an eclipse plugins expert and really don't get the difference between the two methods, but google-ing for the error someone suggested a double import could be causing a version discrepancy, or an attempt to modify a core java functionality. I guess the Required-Bundle approach resolves better the dependencies and prevents this error form poping.
Horacio
Kinori Tech
FUDForum. Page generated in 0.03694 seconds
