Home » Eclipse Projects » Standard Widget Toolkit (SWT) » html5 placeholder like for SWT
html5 placeholder like for SWT [message #665368] Thu, 14 April 2011 13:01 Go to next message
Luiz E. is currently offline Luiz E.Friend
hi all!
when i open the 'Install new software' window, the field used to filter the plugins has a html5 like placeholder wrote 'type filter text'
how can i do that?
thanks
Re: html5 placeholder like for SWT [message #665539 is a reply to message #665368] Fri, 15 April 2011 02:27 Go to previous messageGo to next message
Lakshmi ShanmugamFriend
You need to use Text.setMessage().
Take a look at this example snippet -- http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/org. eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet309 .java
Lakshmi P Shanmugam
Re: html5 placeholder like for SWT [message #665559 is a reply to message #665539] Fri, 15 April 2011 05:56 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
.... but this only works when using SWT.SEARCH!
Tom
Am 15.04.11 04:27, schrieb Lakshmi Shanmugam:
Re: html5 placeholder like for SWT [message #665567 is a reply to message #665559] Fri, 15 April 2011 06:22 Go to previous messageGo to next message
It is used typically used with SWT.SEARCH, but Text.setMessage() works for all Text widgets with SWT.SINGLE style.
Lakshmi P Shanmugam
Re: html5 placeholder like for SWT [message #665645 is a reply to message #665559] Fri, 15 April 2011 11:07 Go to previous messageGo to next message
i'm using SWT.SEARCH Very Happy
thanks a lot, guys, works perfect now!
Re: html5 placeholder like for SWT [message #665667 is a reply to message #665645] Fri, 15 April 2011 12:39 Go to previous messageGo to next message
i made a search text widget like this:
package br.com.germantech.widgets;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.ModifyEvent;
import org.eclipse.swt.events.ModifyListener;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Text;
public abstract class SearchText extends Text implements ModifyListener{
	public SearchText(Composite parent) {
		super(parent, SWT.SEARCH | SWT.ICON_SEARCH | SWT.ICON_CANCEL);
		setMessage("Buscar...");
		addModifyListener(this);
	public void modifyText(ModifyEvent e) {
		doModify();
	protected void checkSubclass() {
		//hacker!
	protected void checkWidget() {
		//hacker!
	public abstract void doModify();
Re: html5 placeholder like for SWT [message #665679 is a reply to message #665667] Fri, 15 April 2011 12:47 Go to previous messageGo to next message
You should not subclass SWT-Widgets, don't blame anybody if your code
gets broken one day.
Tom
Am 15.04.11 14:39, schrieb luizk:
> @Override
> doModify();
> @Override
> //hacker!
> @Override
> //hacker!
Re: html5 placeholder like for SWT [message #665688 is a reply to message #665679] Fri, 15 April 2011 13:58 Go to previous message
hi tom!
is there an appropriate way to do the same thing that i've done?
Previous Topic:FileFieldEditor Help
Next Topic:Intransparent shape on an transparent shell
Current Time: Thu Sep 24 23:06:24 GMT 2020
Powered by FUDForum. Page generated in 0.02809 seconds
