Home » Eclipse Projects » Dali » Unable to get Entity back from database as the Entity object.(Data is returned as a java.lang.Object not my Entity object.)
Unable to get Entity back from database as the Entity object. [message #665241] Wed, 13 April 2011 20:28 Go to next message
ekim  is currently offline ekim Friend
So, I am up and running with Helios (for Java EE Developers) and trying to hit our databasae (Sybase) to retrieve data from some (any) table.
Also installed EclipseLink 2.0 (did I need this?)
I created a Java class to align with a DB table and added javax.persistence.* annotations, setter and getters and implemented Serializable.
I have test code that uses EntityManagerFactory to get an EntityManager that uses createNativeQuery(...).getResultList() and I do get a result list. However the result list contains Objects rather than my Entity objects. While debuging I can see the contents of the object but get a casting exception anytime I try to use the Object as an Entity.
I then found the "Entities From Tables" and re-generated my entity this way - essentially the same class but, still get the same Object result.
[Ljava.lang.Object; cannot be cast to com.jpa.test.ImagePerson
at com.jpa.test.Main.main(Main.java:29)
What am I missing, doing wrong or not doing?
-mike
Re: Unable to get Entity back from database as the Entity object. [message #665259 is a reply to message #665241] Wed, 13 April 2011 22:09 Go to previous messageGo to next message
Neil Hauge is currently offline Neil HaugeFriend
You don't need EclipseLink specifically, but you do need a JPA implementation, which EclipseLink provides.
Did you pass a resultClass parameter to createNativeQuery(...)? If not, this would explain why you got back objects instead of instances of your entity.
If you are getting started with JPA, I recommend picking up "Pro JPA 2" by Mike Keith and Merrick Schincariol.
Neil
Re: Unable to get Entity back from database as the Entity object. [message #665265 is a reply to message #665259] Wed, 13 April 2011 23:27 Go to previous messageGo to next message
I wondered if Dali was doing somthing that you once needed EclipseLink (or other, Hibernate, OpenLink, etc.) for - OK so that's not the issue.
Yes I passed a simple SQL "SELECT * FROM tableName" for the method call.
Thanks for the book recommendation, new to Web Services in general (not just JPA) - coming from core and OSGi programming.
Re: Unable to get Entity back from database as the Entity object. [message #665526 is a reply to message #665259] Thu, 14 April 2011 22:35 Go to previous message
So, after RTFM . . .
I was not using the EntityManager [em.createNativeQuery()] methods properly. It accepts native SQL or JPQL with/without the Entity class and when I understood the how and why it worked as expected.
Thanks again for the book recommendation.
Previous Topic:Unable to generate JAXB classes
Next Topic:provisional API changes
Current Time: Fri Aug 14 18:47:35 GMT 2020
Powered by FUDForum. Page generated in 0.02113 seconds
