Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT large component widget question
SWT large component widget question [message #665018] Tue, 12 April 2011 20:01 Go to next message
Originally posted by: nospam.somewhere.org
A large swt widget component shall be implemented. A gantt diagram may
be an example for this component:
- a small part is visible, horizontal and vertical scrollbars are used
to scroll to currently invisible areas
- the number of horizontal and vertical elements is dynamic
- any (visible) element is choosable and shows a context menu
Simply implementing a paint listener may have poor performance if there
are many elements in the invisible are. Also the scrollbars shall
support smooth scrolling.
In which way can such component be implemented?
Markus
Re: SWT large component widget question [message #665026 is a reply to message #665018] Tue, 12 April 2011 22:03 Go to previous messageGo to next message
Markus,
It sounds like something you might want to use GEF/Draw2D to implement.
> there are many elements in the invisible are. Also the scrollbars
> shall support smooth scrolling.
> Markus
Re: SWT large component widget question [message #665051 is a reply to message #665018] Wed, 13 April 2011 06:02 Go to previous message
Thomas Schindl is currently offline Thomas SchindlFriend
There's a gant control in Nebula.
Tom
Am 12.04.11 22:01, schrieb Ceeper:
> Markus
Previous Topic:[SOLVED] Recover from SWT Error
Next Topic:ScrollableComposite
Current Time: Mon Mar 30 01:29:42 GMT 2020
Powered by FUDForum. Page generated in 0.02714 seconds
