Re: Can't update "Eclipse for RCP and RAP Developers" [message #666567 is a reply to message #665001] |
Thu, 21 April 2011 03:16 |
David Williams Messages: 176 Registered: July 2009 |
On 04/12/2011 02:22 PM, Eric Jain wrote:
> When I run "Help" > "Check for Updates" I can see that there is an
> update available, but it can't be installed:
Not sure if related to your case, but there's been some similar cases
discussed in bug 339659 [1]. I haven't read it close enough to know what
the actual problem is, but seemed what helped some people was to run as
Eclipse (for the update) as "root" (Administrator) so they'd have the
right permissions for a "shared installed".
If that helps you, or doesn't, you might document your experiences in
that bug ... or, open a new one, if doesn't help, and you have some new
case.
HTH
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=339659
FUDForum. Page generated in 0.03417 seconds
