MoDisco changing Model Load behavior [message #664871] |
Tue, 12 April 2011 11:01 |
Anders Olsson Messages: 21 Registered: July 2009 |
What I'm trying to do is load a file according to my Meta-Model from code like so:
ResourceSet resourceSet = new ResourceSetImpl();
Resource myRes = resourceSet.createResource(myFileUri, MyMetaModelPackage.eNS_URI);
myRes.load(null);
EObject myObj = xmlRes.getContents().get(0);
myFileUri points to a file on the local filesystem. MyMetaModelPackage.eNS_URI contins the namespace of the Meta-Model.
In the case where the file extension is the expected (the one specified in the genmodel), things work as expected. myRes gets loaded as an XMIResource and myObj is of the expected Meta-Model type.
However if myFileUri points to a file with identical content, but with a different file extension, things behave differently. Then myRes gets the type 'org.eclipse.gmt.modisco.xml.resource.GenericXMLResourceImpl ' and myObj is a 'org.eclipse.gmt.modisco.xml.emf.impl.RootImpl' with the name of the first element in the model file.
Thing is if I uninstall MoDisco (version 0.8.2.v201102100957) and repeat the process where I load the file with the wrong file extension, things work just normal. I get an XMIResource, and the EObject I get out is of my Meta-Model type.
Is this a known bug in MoDisco, or is it expected behavior? Is there a way I should do my loading so MoDisco doesn't interfere?
Thanks in advance for any clarifications,
Anders
Re: MoDisco changing Model Load behavior [message #664982 is a reply to message #664871] |
Tue, 12 April 2011 16:22 |
Ed Merks Messages: 33136 Registered: July 2009 |
--------------060500000507030903090101
Anders,
Even if you make use of content types like the one registered for XMI
<extension
point="org.eclipse.core.contenttype.contentTypes">
<content-type
base-type="org.eclipse.core.runtime.xml"
* file-extensions="xmi"*
id="org.eclipse.emf.ecore.xmi"
name="%_UI_XMI_content_type"
priority="normal">
<describer
class=" org.eclipse.emf.ecore.xmi.impl.XMLContentHandlerImpl$XMI$Des criber "/>
</content-type>
</extension>
you still need to specify which file extensions to inspect for that type
of content. So it's up to you to ensure you have sufficient
registrations against extensions if that's sufficiently unique or a
combination of content types and extension (if you want to use xml as
your extension for example) to get the behavior you desire.
Anders Olsson wrote:
> code like so:
> myRes.load(null);
> Anders
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Anders,<br>
<br>
Even if you make use of content types like the one registered for XMI<br>
<br>
<small> <extension<br>
point="org.eclipse.core.contenttype.contentTypes"><br >
<content-type<br>
base-type="org.eclipse.core.runtime.xml"<br>
<b> file-extensions="xmi"</b><br>
id="org.eclipse.emf.ecore.xmi"<br>
name="%_UI_XMI_content_type"<br>
priority="normal"><br>
<describer
class=" org.eclipse.emf.ecore.xmi.impl.XMLContentHandlerImpl$XMI$Des criber "/><br>
</content-type><br>
</extension></small><br>
<br>
type of content. So it's up to you to ensure you have sufficient
your extension for example) to get the behavior you desire.<br>
<br>
<br>
<blockquote cite="mid:io1avg$n8l$1@news.eclipse.org" type="cite">Hi,
<br>
<br>
code like so:
<br>
<br>
<br>
myRes.load(null);
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Anders
<br>
</blockquote>
</body>
</html>
--------------060500000507030903090101--
Ed Merks
FUDForum. Page generated in 0.02620 seconds
