Re: Correct way to specify rowFetchSize [message #664851 is a reply to message #664731] |
Tue, 12 April 2011 09:29 |
In the debugger what did you change it to? You can always use a
beforeOpen script on the dataset and set a property like:
this.setExtensionProperty("propertyname","propvalue");
Jason
On 4/11/2011 1:57 PM, john.h.liptak@gmail.com wrote:
> In org.eclipse.birt.report.data.oda.jdbc.Statement.setProperty( ) there
> is an if/then/else clause that will set the JDBC fetch size (not the
> fetch limit).
> I can't figure out how to call the property correctly.
> If I add the following properties to my data set:
> <property name="queryTimeOut">75</property>
> <property name="rowFetchSize">234</property>
> </oda-data-set>
> and set the debugger to break when setProperty is called, the breakpoint
> is het for the queryTimeOut property but not for rowFetchSize. If I
> modify the property name in the debugger, I get exactlly the behavior
> I'm looking for.
FUDForum. Page generated in 0.03726 seconds
