Home » Language IDEs » ServerTools (WTP) » Project not published after change(Project not published after change)
Project not published after change [message #664470] |
Sat, 09 April 2011 09:12 |
No real name Messages: 1 Registered: April 2011 |
Hi all,
I'm using the following setup:
Version: Eclipse Helios Service Release 2
Build id: 20110218-0911
Ubuntu 10.10
Myfaces 2.0.3
Tomcat 7.0.11
At the beginning I created a new JSF 2 project (Dynamic Web Project, Name: ela), I created an index.jsf and everything worked fine, I was able to run the project on the server as expected without any issues.
But when I did a change on the index.jsf and republished the project on the running server the changes weren't reflected / visible in the loaded page (i.e. still the old index.jsf was displayed).
Meanwhile I tried differents setups (tomcat6, eclipse galileo) but the issue is the same for everything I tried.
Since I don't want to restart the server for each small change (when I do this the changes are visible), is there anything I can do to solve this issue?
Below some details regarding the settings in the project:
web.xml:
<web-app xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://java.sun.com/xml/ns/javaee" xmlns:web="http://java.sun.com/xml/ns/javaee/web-app_2_5.xsd" xsi:schemaLocation="http://java.sun.com/xml/ns/javaee http://java.sun.com/xml/ns/javaee/web-app_2_5.xsd" id="WebApp_ID" version="2.5">
<display-name>test</display-name>
<welcome-file-list>
<welcome-file>index.html</welcome-file>
<welcome-file>index.htm</welcome-file>
<welcome-file>index.jsp</welcome-file>
<welcome-file>default.html</welcome-file>
<welcome-file>default.htm</welcome-file>
<welcome-file>default.jsp</welcome-file>
</welcome-file-list>
<servlet>
<servlet-name>Faces Servlet</servlet-name>
<servlet-class>javax.faces.webapp.FacesServlet</servlet-class>
<load-on-startup>1</load-on-startup>
</servlet>
<servlet-mapping>
<url-pattern>*.faces</url-pattern>
<url-pattern>/faces/*</url-pattern>
</servlet-mapping>
<context-param>
<param-name>javax.servlet.jsp.jstl.fmt.localizationContext</param-name>
<param-value>resources.application</param-value>
</context-param>
<context-param>
<description>State saving method: 'client' or 'server' (=default). See JSF Specification 2.5.2</description>
<param-name>javax.faces.STATE_SAVING_METHOD</param-name>
<param-value>client</param-value>
</context-param>
<context-param>
<description>
This parameter tells MyFaces if javascript code should be allowed in
the rendered HTML output.
If javascript is allowed, command_link anchors will have javascript code
that submits the corresponding form.
If javascript is not allowed, the state saving info and nested parameters
will be added as url parameters.
Default is 'true'</description>
<param-name>org.apache.myfaces.ALLOW_JAVASCRIPT</param-name>
<param-value>true</param-value>
</context-param>
<context-param>
<description>
If true, rendered HTML code will be formatted, so that it is 'human-readable'
i.e. additional line separators and whitespace will be written, that do not
influence the HTML code.
<param-name>org.apache.myfaces.PRETTY_HTML</param-name>
</context-param>
<context-param>
<param-name>org.apache.myfaces.DETECT_JAVASCRIPT</param-name>
<param-value>false</param-value>
</context-param>
<context-param>
<description>
If true, a javascript function will be rendered that is able to restore the
former vertical scroll on every request. Convenient feature if you have pages
with long lists and you do not want the browser page to always jump to the top
if you trigger a link or button action that stays on the same page.
Default is 'false'
</description>
<param-name>org.apache.myfaces.AUTO_SCROLL</param-name>
</context-param>
<listener>
<listener-class>org.apache.myfaces.webapp.StartupServletContextListener</listener-class>
</listener>
</web-app>
server.xml
Licensed to the Apache Software Foundation (ASF) under one or more
contributor license agreements. See the NOTICE file distributed with
this work for additional information regarding copyright ownership.
The ASF licenses this file to You under the Apache License, Version 2.0
(the "License"); you may not use this file except in compliance with
the License. You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
--><!-- Note: A "Server" is not itself a "Container", so you may not
define subcomponents such as "Valves" at this level.
Documentation at /docs/config/server.html
--><Server port="8005" shutdown="SHUTDOWN">
<!-- Security listener. Documentation at /docs/config/listeners.html
<Listener className="org.apache.catalina.security.SecurityListener" />
<!--APR library loader. Documentation at /docs/apr.html -->
<Listener SSLEngine="on" className="org.apache.catalina.core.AprLifecycleListener"/>
<!--Initialize Jasper prior to webapps are loaded. Documentation at /docs/jasper-howto.html -->
<Listener className="org.apache.catalina.core.JasperListener"/>
<!-- Prevent memory leaks due to use of particular java/javax APIs-->
<Listener className="org.apache.catalina.core.JreMemoryLeakPreventionListener"/>
<Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener"/>
<Listener className="org.apache.catalina.core.ThreadLocalLeakPreventionListener"/>
<!-- Global JNDI resources
Documentation at /docs/jndi-resources-howto.html
<GlobalNamingResources>
<!-- Editable user database that can also be used by
UserDatabaseRealm to authenticate users
<Resource auth="Container" description="User database that can be updated and saved" factory="org.apache.catalina.users.MemoryUserDatabaseFactory" name="UserDatabase" pathname="conf/tomcat-users.xml" type="org.apache.catalina.UserDatabase"/>
</GlobalNamingResources>
<!-- A "Service" is a collection of one or more "Connectors" that share
a single "Container" Note: A "Service" is not itself a "Container",
so you may not define subcomponents such as "Valves" at this level.
Documentation at /docs/config/service.html
<Service name="Catalina">
<!--The connectors can use a shared executor, you can define one or more named thread pools-->
<Executor name="tomcatThreadPool" namePrefix="catalina-exec-"
maxThreads="150" minSpareThreads="4"/>
<!-- A "Connector" represents an endpoint by which requests are received
and responses are returned. Documentation at :
Java HTTP Connector: /docs/config/http.html (blocking & non-blocking)
Java AJP Connector: /docs/config/ajp.html
APR (HTTP/AJP) Connector: /docs/apr.html
Define a non-SSL HTTP/1.1 Connector on port 8080
<Connector connectionTimeout="20000" port="8080" protocol="HTTP/1.1" redirectPort="8443"/>
<!-- A "Connector" using the shared thread pool-->
<Connector executor="tomcatThreadPool"
redirectPort="8443" />
<!-- Define a SSL HTTP/1.1 Connector on port 8443
This connector uses the JSSE configuration, when using APR, the
connector should be using the OpenSSL style configuration
described in the APR documentation -->
<Connector port="8443" protocol="HTTP/1.1" SSLEnabled="true"
maxThreads="150" scheme="https" secure="true"
clientAuth="false" sslProtocol="TLS" />
<!-- Define an AJP 1.3 Connector on port 8009 -->
<Connector port="8009" protocol="AJP/1.3" redirectPort="8443"/>
<!-- An Engine represents the entry point (within Catalina) that processes
every request. The Engine implementation for Tomcat stand alone
analyzes the HTTP headers included with the request, and passes them
on to the appropriate Host (virtual host).
Documentation at /docs/config/engine.html -->
<!-- You should set jvmRoute to support load-balancing via AJP ie :
<Engine name="Catalina" defaultHost="localhost" jvmRoute="jvm1">
<Engine defaultHost="localhost" name="Catalina">
<!--For clustering, please take a look at documentation at:
/docs/cluster-howto.html (simple how to)
/docs/config/cluster.html (reference documentation) -->
<Cluster className="org.apache.catalina.ha.tcp.SimpleTcpCluster"/>
<!-- Use the LockOutRealm to prevent attempts to guess user passwords
via a brute-force attack -->
<Realm className="org.apache.catalina.realm.LockOutRealm">
<!-- This Realm uses the UserDatabase configured in the global JNDI
resources under the key "UserDatabase". Any edits
that are performed against this UserDatabase are immediately
available for use by the Realm. -->
<Realm className="org.apache.catalina.realm.UserDatabaseRealm" resourceName="UserDatabase"/>
</Realm>
<Host appBase="webapps" autoDeploy="true" name="localhost" unpackWARs="true">
<!-- SingleSignOn valve, share authentication between web applications
Documentation at: /docs/config/valve.html -->
<Valve className="org.apache.catalina.authenticator.SingleSignOn" />
<!-- Access log processes all example.
Note: The pattern used is equivalent to using pattern="common" -->
<Valve className="org.apache.catalina.valves.AccessLogValve" directory="logs" pattern="%h %l %u %t "%r" %s %b" prefix="localhost_access_log." resolveHosts="false" suffix=".txt"/>
<Context docBase="ela" path="/ela" reloadable="true" source="org.eclipse.jst.jee.server:ela"/><Context docBase="elanew" path="/elanew" reloadable="true" source="org.eclipse.jst.jee.server:elanew"/><Context docBase="test" path="/test" reloadable="true" source="org.eclipse.jst.jee.server:test"/></Host>
</Engine>
</Service>
</Server>
Many thanks
Re: Project not published after change [message #664628 is a reply to message #664470] |
Mon, 11 April 2011 12:53 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
See the Tomcat FAQ[1] about where the project is being published and
confirm if the changed JSF is being updated at the publish destination.
Since restarting the server works, I would assume the answer is yes.
This would imply this issue is with Myfaces and potentially Tomcat.
Larry
[1] http://wiki.eclipse.org/WTP_Tomcat_FAQ
On 4/9/2011 5:12 AM, duehrbert@gmx.de wrote:
> Hi all,
> Ubuntu 10.10
> Myfaces 2.0.3
> Tomcat 7.0.11
> issue is the same for everything I tried. Since I don't want to restart
> web.xml:
> version="2.5">
> <welcome-file-list>
> <servlet>
> <servlet-class>javax.faces.webapp.FacesServlet</servlet-class >
> </servlet>
> <servlet-mapping>
> </servlet-mapping>
> <context-param>
> <param-name>javax.servlet.jsp.jstl.fmt.localizationContext</param-name >
> </context-param>
> <context-param>
> </context-param>
> <context-param>
> <description>
> <param-name>org.apache.myfaces.ALLOW_JAVASCRIPT</param-name >
> </context-param>
> <context-param>
> <description>
> 'human-readable'
> </context-param>
> <context-param>
> <param-name>org.apache.myfaces.DETECT_JAVASCRIPT</param-name >
> </context-param>
> <context-param>
> <description>
> pages
> the top
> Default is 'false'
> </description>
> </context-param>
> <listener>
> <listener-class>org.apache.myfaces.webapp.StartupServletContextListener </listener-class>
> </listener>
> </web-app>
> server.xml
> className="org.apache.catalina.core.AprLifecycleListener"/ >
> <Listener
> className="org.apache.catalina.core.JreMemoryLeakPreventionListener "/>
> <Listener
> className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener "/>
> <Listener
> className="org.apache.catalina.core.ThreadLocalLeakPreventionListener "/>
> updated and saved"
> factory="org.apache.catalina.users.MemoryUserDatabaseFactory "
> a single "Container" Note: A "Service" is not itself a "Container", so
> port="8080" protocol="HTTP/1.1" connectionTimeout="20000"
> --> <!-- Define a SSL HTTP/1.1 Connector on port 8443
> <Engine name="Catalina" defaultHost="localhost" jvmRoute="jvm1"> -->
> </Realm>
> unpackWARs="true">
> </Engine>
> </Service>
> </Server>
> Many thanks
Current Time: Thu Apr 25 10:39:55 GMT 2024
Powered by FUDForum. Page generated in 0.02818 seconds
