Re: Maximizing a Part [message #666402 is a reply to message #665640] |
Wed, 20 April 2011 10:37 |
Christoph Keimel Messages: 482 Registered: December 2010 Location: Germany |
following the discussion in Bug 342947 I have checked out the current plug-in from HEAD. I initially got some NullPointerExceptions because I have no "EDITOR_AREA" defined.
It seems to me, that it is necessary to define an Element with the ID set ID_EDITOR_AREA. What is this for and how does it work?
Christoph
P.S. If I modify the code to not use the EDITOR_AREA by check for null, the maximize button will just switch to Restore-Mode without maximizing the PartStack.
Changes:
MinMaxAddon_changes.pdf
[Updated on: Wed, 20 April 2011 10:41] Report message to a moderator
FUDForum. Page generated in 0.03785 seconds
