Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Parameters of one operation([Acceleo] PArameters of one operation)
[Acceleo] Parameters of one operation [message #663884] Wed, 06 April 2011 13:27 Go to next message
Hello
I you can you please tell me how I can check if an operation has parameters?
I tried with
[query private hasNotParameterOperation(o : Operation) : Boolean = if o.ownedParameter -> isEmpty() then true else false endif/]
but, I failed. This will invoke from the other query to obtain all types of the parameters of all operations of the class
[query private getSetAllParamsTypeName(c : Class) : Set(String) = c.ownedOperation ->
select(o : Operation | not o.hasNotParameterOperation()) -> ownedParameter -> collect(type.name) -> asSet() /]
As you can see the final objective is to obtain all the parameters of a class, the middle Quiery put it because I saw that if he had an operation without parameters failed me.
In advance, thanks
Re: [Acceleo] Parameters of one operation [message #664074 is a reply to message #663884] Thu, 07 April 2011 08:26 Go to previous messageGo to next message
If you want to find if an operation has any parameters:
[for (anOperation : Operation | class.ownedOperation)]
[anOperation.ownedParameter->isEmpty()/]
[/for]
If you want to find all the parameters from all the operations of a class:
[class.ownedOperation-> union(class.getImplementedInterfaces().ownedOperation).owned Parameter/]
You would also need to look for the parameters from abstract method coming from the superclasses etc.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Acceleo wiki: http://wiki.eclipse.org/Acceleo
Blogs: http://stephanebegaudeau.tumblr.com & http://sbegaudeau.tumblr.com
Re: [Acceleo] Parameters of one operation [message #664580 is a reply to message #664074] Mon, 11 April 2011 05:47 Go to previous messageGo to next message
Thanks for your response.
My goal is to generate the "Imports " of class that I am modeling, regardless of its superclasses. I do the following:
[query private getSetAllParamsTypeNameSimples(c : Class) : Set(String) = getBagAllParams(c) -> collect(type.name) -> asSet() /]
[query private getBagAllParams(c : Class) : Bag(Parameter) = c.ownedOperation->ownedParameter -> asBag() /]
This works fine when all class operations with parameters in a class that has an operation without parameters neither input nor output gives me the following error:
Invalid result for expression getBagAllParams(c)->collect(temp5 : Parameter | temp5.type.name)->asSet() at line 219 in Module generateHelpers for query getSetAllParamsTypeNameSimples(Class). Last recorded value of self was org.eclipse.uml2.uml.internal.impl.ClassImpl@1fc89e9 (name: GccomMantUnidadesHelper, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false).
Re: [Acceleo] Parameters of one operation [message #664581 is a reply to message #664580] Mon, 11 April 2011 05:48 Go to previous messageGo to next message
Sorry, in my previous post is missing farewell
Thanks for your help
Re: [Acceleo] Parameters of one operation [message #664714 is a reply to message #663884] Mon, 11 April 2011 12:48 Go to previous messageGo to next message
PD: I'm not user of eclipse forum and I can not see my first reply, forgive me if you see this message 2 times.
Re: [Acceleo] Parameters of one operation [message #664828 is a reply to message #663884] Tue, 12 April 2011 04:41 Go to previous messageGo to next message
First of all, this query should not work:
It may be a typo of your message in this newsgroup but it should be:
[query private getBagAllParams(c : Class) : Bag(Parameter) = c.ownedOperation.ownedParameter -> asBag() /]
The message invalid result is returned if your query return a "null". The class "GccomMantUnidadesHelper" may be a class with methods without parameters. To solve your problem, you could try something like this:
[query private getBagAllParams(c : Class) : Bag(Parameter) = c.ownedOperation->select(ownedParameter->size() > 0).ownedParameter->asBag() /]
Re: [Acceleo] Parameters of one operation [message #664839 is a reply to message #664828] Tue, 12 April 2011 05:13 Go to previous messageGo to next message
Hi Stephane
No it's ok. There is an implicit toCollection operation that I'm
proposing to reify as an explicit OclAny::oclAsSet() operation.
The first example is therefore just inefficient:
c.ownedOperation.oclAsSet()->collect(ownedParameter)-> asBag()
Ed Willink
Re: [Acceleo] Parameters of one operation [message #665657 is a reply to message #663884] Fri, 15 April 2011 08:03 Go to previous messageGo to next message
Thanks for your answers
Using the option that tells me Sthepane working fine. With the option of Edward It can't find the method "oclAsSet () ".
Again, thank you
Re: [Acceleo] Parameters of one operation [message #665666 is a reply to message #665657] Fri, 15 April 2011 08:30 Go to previous message
There is no oclAsSet() method. I used it to clarify the implicit conversion.
I wrote that I'm proposing to reify it so that it can be used and
overloaded.
Ed Willink
> Again, thank you
Previous Topic:[Acceleo] eContainer returns invalid class
Next Topic:[Acceleo] Problems with UI launcher project
Current Time: Tue Jun 17 23:47:03 EDT 2025
Powered by FUDForum. Page generated in 0.16669 seconds
