Re: model query [message #663819] |
Wed, 06 April 2011 14:49 |
Ed Merks Messages: 33141 Registered: July 2009 |
Chuck,
This sounds more likely to be an OCL question so I've added the OCL
newsgroup/forum to the to list of my reply.
chuck wrote:
> hello guys!
> i'm using model query to do some queries and update on my model...
> the steps that i done, are:
> -generate from genmodel of my metamodel every model classes ...
> -register metamodel and after call a method that has to read a model...
> -in this method :
> ResourceSet resourceSet = new ResourceSetImpl();
> URI modelUri = URI.createFileURI(new
> File("model/mymodel.ecore").getAbsolutePath());
> EcoreResourceFactoryImpl ecoreFactory = new
> EcoreResourceFactoryImpl();
> resourceSet.getResourceFactoryRegistry().getExtensionToFacto
> ryMap().put( "ecore", ecoreFactory);
> // Demand load resource for this file.
> Resource resource = resourceSet.getResource(modelUri, true);
> System.out.println("Loaded " + modelUri);
> OCL ocl = org.eclipse.ocl.ecore.OCL.newInstance();
> EObjectCondition condition = new
> BooleanOCLCondition<EClassifier, EClass, EObject>(
> ocl.getEnvironment(), "self.elements", MyMMPackage.Literals.MOD);
> SELECT statement = new SELECT(SELECT.UNBOUNDED, false, new
> FROM(resource.getContents()), new WHERE(condition));
> IQueryResult results = statement.execute(); // do something with the
> results
> System.out.println("SIZE: " + results.size());
> but i receive error like that: java.lang.ClassCastException:
> org.eclipse.emf.ecore.impl.EFactoryImpl cannot be cast to
> MyMM.MyMMFactory
> the problem is solved if I change query from "self.elements" to for
> example self.oclIsTypeOf("MyMM::metaclass")
> what it's wrong?!?!?
> thx
Ed Merks
Re: model query [message #663844 is a reply to message #663819] |
Wed, 06 April 2011 15:47 |
Ed Willink Messages: 7655 Registered: July 2009 |
This isn't actually an OCL problem, but an EMF Query issue.
As Axel observes, you may not be using Boolean. The CCE certainly looks
like a data type construction issue, but since you only provide 25% of
the problem report we can only provide 25% of the answer.
Ed Willink
On 06/04/2011 15:49, Ed Merks wrote:
> Chuck,
> chuck wrote:
>> hello guys!
>> -in this method :
>> results
>> MyMM.MyMMFactory
>> thx
FUDForum. Page generated in 0.03403 seconds
