Home » Eclipse Projects » Standard Widget Toolkit (SWT) » [SOLVED] Accessing files on NAS network drive from Linux(Is it possible to access NAS from Linux using SWT?)
icon5.gif  [SOLVED] Accessing files on NAS network drive from Linux [message #663518] Tue, 05 April 2011 13:25 Go to next message
Albert Pikus is currently offline Albert PikusFriend
Member
I wonder if it's possible to access files on NTFS network drive from SWT application running on Linux. I'm using Ubuntu 10.04 and when I browse files using Nautilus, "Network" folder and NAS drive inside it can be seen and files can be manipulated from my Linux box.
But when I try to manipulate files on NAS from my SWT application, using FileDialog, folder "Network" can't be seen at all. Is there any way I could access those files using SWT FileDialog?
Albert
[Updated on: Thu, 07 April 2011 09:28]
Report message to a moderator
Re: Accessing files on NAS network drive from Linux [message #663616 is a reply to message #663518] Tue, 05 April 2011 21:13 Go to previous messageGo to next message
Fabian Bernhard is currently offline Fabian BernhardFriend
The "Network" folder in Nautilus is not a real folder but rather a shortcut to where your NAS is actually mounted.
Most probably the network drive is mounted in /mnt or /media/*. Try to look there for your files. To find the exact mount point of your network drive, type "mount" in a console. It will list you all mounted drives.
Re: Accessing files on NAS network drive from Linux [message #664041 is a reply to message #663616] Thu, 07 April 2011 09:25 Go to previous message
Member
thank you for your answer. Yes, you are right, once the NAS share is mounted to some directory, my SWT application can access files from there.
Albert
Previous Topic:File Save Dialog - No Directory content is shown
Next Topic:[Nebula] Collapsible Buttons don't collapse, won't fill with data
Current Time: Wed Mar 03 22:24:40 GMT 2021
Powered by FUDForum. Page generated in 0.01449 seconds
