Re: Slow concurrent report generation [message #663648 is a reply to message #663379] |
Wed, 06 April 2011 02:49 |
Ricardo,
Are all tasks being closed? Are you using runandrender task or run task
followed by render task?
Jason
On 4/4/2011 3:53 PM, Ricardo Fernandes wrote:
> I've a web application running in Jboss that have lots of concurrent
> users. At a given time, lots of reports are generated.
> In this scenario, sometimes reports run very slow! They appear to be
> waiting for something and then continue. I'm using a Servlet (almost
> equal to the reference servlet) to handle report generation.
> Taking a dump of the threads running, I've noticed something strange:
> org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder.b
> uild(ReportQueryBuilder.java:256)
> - locked <0x45a228> (a org.eclipse.birt.report.engine.ir.Report)
> uild(ReportQueryBuilder.java:237)
> Do you think there's anything related to this? The 'locked' keyword took
> my attention, but I don't know what could be causing this! Any clues?
> thanks a lot in advance, Ricardo
Re: Slow concurrent report generation [message #663980 is a reply to message #663730] |
Thu, 07 April 2011 05:03 |
Are you using the Graphical query builder in your datasources or the
normal jdbc datasource. I think this error message needs to be logged
as a bugzilla entry. Any chance you could do that?
Jason
On 4/6/2011 7:04 AM, Ricardo Fernandes wrote:
> Hi, Jason,
> All tasks are being closed and I'm using runandrender. Should I try run,
> then render?
> thanks in advance!
Re: Slow concurrent report generation [message #664836 is a reply to message #664736] |
Tue, 12 April 2011 09:09 |
Can you post the code you are using? Are you using runandrender task or
separate run and then render task?
Jason
On 4/11/2011 2:45 PM, Ricardo Fernandes wrote:
> Another info: looking at the thread dump, I've noticed there are lots of
> threads related to birt that are in "Runnable" state.
Re: Slow concurrent report generation [message #758104 is a reply to message #757826] |
Mon, 21 November 2011 21:30 |
Gustavo
Are you having this issue?
This looks to me like task where not being closed or the rptdocument not
being closed.
Jason
On 11/21/2011 2:26 PM, Gustavo Lanna wrote:
> Ricardo,
> Have you solved this problem?
> Thanks
Re: Slow concurrent report generation [message #759488 is a reply to message #758826] |
Mon, 28 November 2011 19:35 |
If you are using the WebViwer the documents should be getting closed
automatically.
Jason
On 11/24/2011 11:21 AM, Gustavo Lanna wrote:
> Jason,
> Thank you for reply! I'm using birt runtime WebViewer, and I do not
> close taks and rptdocuments. There is a way to do this in WebViewer?
> Gustavo
FUDForum. Page generated in 0.03894 seconds
