Home » Eclipse Projects » Standard Widget Toolkit (SWT) » how do i add a combo to a grid?(getting an unsupported exception )
icon5.gif  how do i add a combo to a grid? [message #663066] Sun, 03 April 2011 05:31 Go to next message
elhanan Maayan is currently offline elhanan MaayanFriend
hi..
i'm trying to add a combo to tableviewer (using wbpro) and i get this:
Exception in thread "main" java.lang.RuntimeException: java.lang.IllegalArgumentException: Widget [org.eclipse.swt.custom.CCombo] is not supported.
at com.model.window.Starter$1.run(Starter.java:32)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at com.model.window.Starter.main(Starter.java:18)
Caused by: java.lang.IllegalArgumentException: Widget [org.eclipse.swt.custom.CCombo] is not supported.
at org.eclipse.jface.internal.databinding.swt.WidgetDelegatingV alueProperty.notSupported(WidgetDelegatingValueProperty.java :23)
at org.eclipse.jface.internal.databinding.swt.WidgetTextWithEve ntsProperty.doGetDelegate(WidgetTextWithEventsProperty.java: 61)
at org.eclipse.core.databinding.property.value.DelegatingValueP roperty.getDelegate(DelegatingValueProperty.java:54)
at org.eclipse.core.databinding.property.value.DelegatingValueP roperty.observe(DelegatingValueProperty.java:88)
at org.eclipse.core.databinding.property.value.ValueProperty$2. createObservable(ValueProperty.java:105)
at org.eclipse.core.internal.databinding.observable.masterdetai l.DetailObservableValue.updateInnerObservableValue(DetailObs ervableValue.java:112)
at org.eclipse.core.internal.databinding.observable.masterdetai l.DetailObservableValue. <init>(DetailObservableValue.java:78)
at org.eclipse.core.databinding.observable.masterdetail.MasterD etailObservables.detailValue(MasterDetailObservables.java:52 )
at org.eclipse.core.databinding.property.value.ValueProperty.ob serveDetail(ValueProperty.java:111)
at org.eclipse.core.internal.databinding.property.ValueProperty DetailValue.observe(ValuePropertyDetailValue.java:68)
at org.eclipse.core.databinding.property.value.ValueProperty.ob serve(ValueProperty.java:91)
at org.eclipse.jface.databinding.viewers.ObservableValueEditing Support$1.doCreateCellEditorObservable(ObservableValueEditin gSupport.java:64)
at org.eclipse.jface.databinding.viewers.ObservableValueEditing Support.initializeCellEditorValue(ObservableValueEditingSupp ort.java:150)
at org.eclipse.jface.viewers.ColumnViewerEditor.activateCellEdi tor(ColumnViewerEditor.java:194)
at org.eclipse.jface.viewers.ColumnViewerEditor.handleEditorAct ivationEvent(ColumnViewerEditor.java:444)
at org.eclipse.jface.viewers.ColumnViewer.triggerEditorActivati onEvent(ColumnViewer.java:680)
at org.eclipse.jface.viewers.ColumnViewer.handleMouseDown(Colum nViewer.java:664)
at org.eclipse.jface.viewers.ColumnViewer.access$0(ColumnViewer .java:660)
at org.eclipse.jface.viewers.ColumnViewer$1.mouseDown(ColumnVie wer.java:89)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:185)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at com.model.window.Starter$1.run(Starter.java:27)
... 2 more
Re: how do i add a combo to a grid? [message #663151 is a reply to message #663066] Mon, 04 April 2011 06:24 Go to previous messageGo to next message
Daniel Krügler is currently offline Daniel KrüglerFriend
On 2011-04-03 07:31, elhanan wrote:
> hi..
> (Realm.java:332)
> gSupport.java:64)
> nViewer.java:664)
> wer.java:89)
> ner.java:185)
> ... 2 more
An error report without a minimalistic code example that demonstrates
how to reproduce the error is - worthless, sorry. Please honor the basic
rules of asking questions in newsgroups, as explained here:
http://www.catb.org/~esr/faqs/smart-questions.html
The following article shows how to use editors in viewers:
http://www.vogella.de/articles/EclipseJFaceTable/article.htm l
HTH & Greetings from Bremen,
- Daniel
Re: how do i add a combo to a grid? [message #663160 is a reply to message #663151] Mon, 04 April 2011 07:33 Go to previous message
thanks, i needed something like it, because in the mean time i found out that it happened becouse i bounded the text attribute of combo and not the selection attribute Sad all them secrets stuff , where can i find them?
Previous Topic:Oops - duplicate
Next Topic:SWT.EMBEDDED problem on OSX
Current Time: Wed Mar 03 22:45:34 GMT 2021
Powered by FUDForum. Page generated in 0.01853 seconds
