Re: Page N of M [message #663356 is a reply to message #662999] |
Mon, 04 April 2011 18:44 |
For the grid where you have one column and one row, select each item and go to the general tab in the property editor and change the "display" setting from "block" to "inline". This should get them on the same row. Let me know.
Michael
www.birt-exchange.org
Michael
Developer Evangelist, Silanis
Re: Page N of M [message #663519 is a reply to message #663439] |
Tue, 05 April 2011 13:26 |
JulioC Missing name Messages: 33 Registered: March 2011 Location: Ottawa, Canada |
Member |
Jani wrote on Tue, 05 April 2011 01:14 | JulioC wrote on Fri, 01 April 2011 17:24 | I'm trying to put in the footer of my master page the variables Page and TotalPageCount
Where do you find those Page and TotalPageCount variables ? I tried to search BIRT Report Designer help without success.
I also found following code snippet:
<page-footer>
<text id="403">
<property name="textAlign">right</property>
<method name="onRender">
this.text = "Page " + pageNumber + " of " + totalPage;
</method>
<property name="contentType">html</property>
</text>
</page-footer>
No idea where those pageNumber and totalPage comes from or how to build such footer with Report Designer thought.
First of all I'm using BIRT 2.6.2
In your report go to the master page
Then choose the palette tab tools, there you will see the autotext variables, under it you have a bunch of variables that you can use in your master page only.
Thanks for the code, I believe it will work when is used in the layout of the report.
JulioC.
[Updated on: Tue, 05 April 2011 13:27] Report message to a moderator
FUDForum. Page generated in 0.05155 seconds
