Home » Modeling » GMF (Graphical Modeling Framework) » How to change the diagram's model at runtime?
How to change the diagram's model at runtime? [message #662167] Tue, 29 March 2011 15:24 Go to next message
Missing name Missing name is currently offline Missing name Missing nameFriend
Hello everybody,
how can I edit a diagram at runtime? The following plug-in code opens an editor at startup and tries to add an EClass to the ECore-Diagram. But it does not work :-/
What's going wrong here?
package testecorediagrameditor;
import java.io.File;
import java.util.Collections;
import org.eclipse.emf.common.ui.URIEditorInput;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.*;
import org.eclipse.emf.ecore.resource.*;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.edit.command.AddCommand;
import org.eclipse.emf.transaction.TransactionalEditingDomain;
import org.eclipse.gmf.ecore.edit.parts.EPackageEditPart;
import org.eclipse.gmf.ecore.part.*;
import org.eclipse.gmf.runtime.diagram.core.services.ViewService;
import org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor;
import org.eclipse.gmf.runtime.notation.Diagram;
import org.eclipse.ui.*;
import org.eclipse.ui.ide.IDE;
public class StartUp implements IStartup {
    ResourceSet resourceSet = new ResourceSetImpl();
    public void earlyStartup() {
        final IWorkbench workbench = PlatformUI.getWorkbench();
        workbench.getDisplay().asyncExec(new TestECoreDiagramEditor());
    private class TestECoreDiagramEditor implements Runnable {
        public void run() {
            try {
                // create an EPackage
                URI ePackageURI = URI.createFileURI("temp_model.ecore");
                EPackage ePackage = EcoreFactory.eINSTANCE.createEPackage();
                ePackage.setName("main package");
                Resource ePackageResource = resourceSet.createResource(ePackageURI);
                ePackageResource.getContents().add(ePackage);
                ePackageResource.save(Collections.EMPTY_MAP);
                new File(ePackageURI.toFileString()).deleteOnExit();
                // create an EPackage diagram
                URI ePackageDiagramURI = URI.createFileURI("temp_model.ecore_diagram");
                Diagram diagram = ViewService.createDiagram(ePackage, EPackageEditPart.MODEL_ID,
                        EcoreDiagramEditorPlugin.DIAGRAM_PREFERENCES_HINT);
                Resource ePackageDiagramResource = resourceSet.createResource(ePackageDiagramURI);
                ePackageDiagramResource.getContents().add(diagram);
                ePackageDiagramResource.save(Collections.EMPTY_MAP);
                new File(ePackageDiagramURI.toFileString()).deleteOnExit();
                // start the editor
                IWorkbenchPage page = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage();
                String editorId = EcoreDiagramEditor.ID;
                IEditorPart editorPart = IDE.openEditor(page, new URIEditorInput(ePackageDiagramURI), editorId);
                // try to add an element to the diagram
                DiagramDocumentEditor editor = (DiagramDocumentEditor) editorPart;
                TransactionalEditingDomain domain = editor.getEditingDomain();
                AddCommand.create(domain, ePackage, EcorePackage.eINSTANCE.getEPackage_EClassifiers(),
                        EcoreFactory.eINSTANCE.createEClass()).execute();
            } catch (Exception e) {
                e.printStackTrace();
best regards
Re: How to change the diagram's model at runtime? [message #662176 is a reply to message #662167] Tue, 29 March 2011 15:43 Go to previous messageGo to next message
I think you need to ensure that you have an absolute path there:
I'm not sure if GMF can deal with file: URIs though.
sricht10@htwm.de wrote:
> Hello everybody,
> import
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor;
> @Override
> @Override
> public void run() {
> try {
> EPackage ePackage =
> new
> // start the editor
> PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
> editorPart;
> best regards
Ed Merks
Re: How to change the diagram's model at runtime? [message #662182 is a reply to message #662176] Tue, 29 March 2011 15:50 Go to previous message
The relative path is no problem for GMF.
I solved my problem by myself Wink The following code works for me.
import java.io.*;
import java.util.*;
import org.eclipse.gmf.runtime.emf.type.core.commands.SetValueCommand;
import org.eclipse.gmf.runtime.emf.type.core.requests.SetRequest;
	private class TestECoreDiagramEditor extends TimerTask implements Runnable {
		private IEditorPart editorPart = null;
		private Timer timer = new Timer();
		public void run() {
			try {
				if (this.editorPart == null) {
					createTempECoreModelWithDiagram(ePackageURI, ePackageDiagramURI);
					// start the editor
					page.closeAllEditors(false);
					this.editorPart = IDE.openEditor(page, new URIEditorInput(ePackageDiagramURI), editorId);
					this.timer.scheduleAtFixedRate(this, 1000, 1000);
				DiagramDocumentEditor editor = (DiagramDocumentEditor) this.editorPart;
				EPackage ePackage = (EPackage) editor.getDiagram().getElement();
				SetRequest setReq = new SetRequest(domain, ePackage, EcorePackage.eINSTANCE.getEPackage_EClassifiers(),
						EcoreFactory.eINSTANCE.createEClass());
				new SetValueCommand(setReq).execute(null, editor);
		private void createTempECoreModelWithDiagram(URI ePackageURI, URI ePackageDiagramURI) throws IOException {
Previous Topic:GMF Developer Guide eclipse 3.6
Next Topic:Selected Node - Which function is called?
Current Time: Fri Dec 06 21:13:20 GMT 2024
Powered by FUDForum. Page generated in 0.03370 seconds
