Home » Modeling » EMF » [CDO] SQL query results
[CDO] SQL query results [message #662162] Tue, 29 March 2011 15:00 Go to next message
Szabolcs Bardy is currently offline Szabolcs BardyFriend
I would like to run SQL queries on the CDO store and return several columns from the database. Unfortunately the CDOQuery returns only the first column when running the query.
Is there a reason why the SQLQueryHandler returns only the first column as a result of an SQL query even if not a CDO object query is run (SQLQueryHandler.CDO_OBJECT_QUERY is set to false)?
The code that returns the result in SQLQueryHandler.executeQuery() is the following:
if (objectQuery)
CDOID result = idHandler.getCDOID(resultSet, 1);
context.addResult(result);
else
Object result = resultSet.getObject(1);
Would it make sense to change it to something like this?
if (objectQuery)
else
int columnCount = resultSet.getMetaData().getColumnCount();
if (columnCount == 1)
else
Object[] results = new Object[columnCount];
for (int i = 0; i < columnCount; i++)
results[i] = resultSet.getObject(i+1);
context.addResult(results);
If the query is not a CDOObject query, the client is probably interested in all of the queried fields.
Szabolcs
Re: [CDO] SQL query results [message #662253 is a reply to message #662162] Tue, 29 March 2011 21:21 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Hi Szabolcs,
I guess we just didn't do it because nobody asked for it in the past. Maybe because the transport protocol is not prepared to deliver arrays of arbitrary objects. Seems you've already played with the code, are you willing to open a bugzilla and attach a patch including some test cases? I'll be back from California next week and could review it then...
Cheers
/Eike
http://www.esc-net.de
Am 29.03.2011 08:00, schrieb Szabolcs Bardy:
> if (objectQuery)
> else
> if (objectQuery)
> else
> else
> Regards,
> Szabolcs
Re: [CDO] SQL query results [message #662395 is a reply to message #662253] Wed, 30 March 2011 14:28 Go to previous message
Hi Eike,
thanks for your answer.
I created a new bugzilla entry (https://bugs.eclipse.org/bugs/show_bug.cgi?id=341363), attached the proposed patch and a test case.
Szabolcs
Previous Topic:[CDO] recover from lost connection
Next Topic:Extend an core Ecore model
Current Time: Mon Feb 17 04:11:00 GMT 2020
Powered by FUDForum. Page generated in 0.11843 seconds
