Re: deploy simple bpel project [message #662156 is a reply to message #662134] |
Tue, 29 March 2011 14:40 |
Hi !
Some things to check:
* was the project created as a "BPEL Project" using the New Project Wizard? Hint: this creates the required project facet.
* have you created and configured an Ode Deployment descriptor (deploy.xml)? Hint: use the New File Wizard
* are all of your artifacts (*.bpel, *.wsdl and *.xsd) in the same project folder or sub-folders? Hint: the default artifacts folder is "bpelContent"
* was Ode installed properly into the tomcat runtime? Hint: see the Apache Ode project site for details
* check the server log to make sure that Ode started correctly (search for BPEL).
Please let me know when you resolve this and what the issue was.
Bob
FUDForum. Page generated in 0.02945 seconds
