Re: Problem using Buckminster to create p2 site with categories [message #662006 is a reply to message #661976] |
Mon, 28 March 2011 20:08 |
Hi Tamar,
I suggest you take a look at one of our site projects.
http://dev.eclipse.org/svnroot/tools/org.eclipse.buckminster /trunk/org.eclipse.buckminster.site.eclipse/
Those two files are all that's needed to a) define the contents of your update site and b) to categorize that content.
You don't need any special properties. Just create a site feature like that and execute its site.p2 action.
Thomas Hallgren
On 2011-03-28 19:19, Tamar Cohen wrote:
> I'm trying to create a p2 site to deliver eclipse-based RCP within my organization. I have been following the various p2
> and buckminster documentation I have found to define categories; I've tried a site.xml, category.xml, and defining the
> catgories within the build.properties file.
> When I call the p2.build step from Buckminster on the feature that contains the p2 definition, the resulting p2
> repository does not have the specified categories, seemingly no matter what I try.
> My latest attempt has all the buckminster.properties contained within the build.properties and the p2 settings are as
> follows:
> bin.includes = feature.xml
> p2.gathering = true
> p2.flavor = tooling p2.publish.artifacts=true p2.category.definition =
> file://absolute/path/gov.nasa.ensemble.eclipse/category.xml
> category.default=gov.nasa.ensemble.eclipse.ide
> I have also set buckminster output levels to debug and so I see this:
> [start gov.nasa.ensemble.eclipse:eclipse.feature$1.0.0.qualifier#si te.p2]
> Product base = ${buckminster.output}/site.p2/
> target.arch=x86_64
> buckminster.component=gov.nasa.ensemble.eclipse
> p2.gathering=true
> p2.publish.artifacts=true category.default=gov.nasa.ensemble.eclipse.ide
> p2.category.definition=file://absolute/path/gov.nasa.ensemble.eclipse/category.xml
> buckminster.component.type=eclipse.feature
> buckminster.version=1.0.0.qualifier
> target.nl=en_US
> target.ws=cocoa
> p2.flavor=tooling target.os=macosx
> target.location=/Applications/eclipse_3.6.2_clean/delta-pack
> QUESTIONS:
> What SHOULD I be doing to have Buckminster create the p2 categories?
> How can I get buckminster to refer to the category.xml file without using the absolute path?
> When I take the same category.xml file, convert it to a site.xml file and use PDE to create the p2 update site, the site
> has the cateogories.
> thanks
> Tamar
FUDForum. Page generated in 0.03283 seconds
