Re: Unable to start JBOSS 5 from eclise IDE [Galileo] [message #662127 is a reply to message #662007] |
Tue, 29 March 2011 13:07 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
On 3/28/2011 4:46 PM, hm9m wrote:
> Yes, the JBOSS is doing an attempt to launch but gets VM argument as
> 16:43:38,494 INFO [ServerInfo] VM arguments:
> -agentlib:jdwp=transport=dt_socket,suspend=y,
> address=localhost:4542 -Dprogram.name=run.bat
> as you notice, suspend=y is creating this problem. I checked run.bat and
> run-conf-bat but nowhere it is setting it as "Y" - so not sure from
> where does it take that value "Y"
> Did full search on c:/
> Thanks.
My guess is that Eclipse starts the JVM suspended to give it a chance to
install breakpoints, should there be any, before resuming. I don't
think it represents something Eclipse is doing wrong. Since you are
seeing this message in the server log, one would assume any breakpoints
have been set and the JVM resumed. :)
Do you see some error or complaint later in the log?
Larry
FUDForum. Page generated in 0.03403 seconds
