Home » Eclipse Projects » Eclipse Platform » How to set background color for UI Element associated with command ?(Set the background color for UI Element associated with command (toolbar item).)
How to set background color for UI Element associated with command ? [message #661829] Mon, 28 March 2011 07:39
Santosh  is currently offline Santosh Friend
I am only a beginner in RCP.
I want to to set background color for UI Element associated with command (toolbar item).
I tried:-
In the method updateElement (UIElement element, Map parameters)
element.setxxx()
But the there was a no such method in the object "element" to set the background color for ui element.
Is there a workaround to set the background color for UI Element associated with the command?
Help would be much appreciated.
Santosh
Previous Topic:CommonNavigator doSave() never gets called.
Next Topic:Problems with product and multi user install
Current Time: Thu Feb 25 06:30:30 GMT 2021
Powered by FUDForum. Page generated in 0.01886 seconds
