Home » Modeling » GMF (Graphical Modeling Framework) » Creating EditPart + setting size no longer working
Creating EditPart + setting size no longer working [message #661637] Fri, 25 March 2011 16:09 Go to next message
Ugo Sangiorgi is currently offline Ugo SangiorgiFriend
Member
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="content-type" content="text/html; charset=ISO-8859-1">
</head>
<tt>Hello, after re-generating my code my CreateViewRequest seems to
be failing on setting the size of my editpart.<br>
I've checked over and over to see if there is something i forgot
to mark as @generated NOT, but everything seems right.<br>
<br>
The editpart is created, but with a default (small) size.<br>
<br>
here is my code, is there something missing?:<br>
<br>
<small>final DiagramEditor editor = (DiagramEditor)
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().getActiveEditor(); <br>
<br>
CreateViewRequest.ViewDescriptor viewDescriptor = new
CreateViewRequest.ViewDescriptor(<br>
&nbsp;&nbsp; &nbsp;new EObjectAdapter(unknown_element), Node.class, &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;
&nbsp;((IHintedType)ShapesElementTypes.Unknown_2003).get SemanticHint(),
true,editor.getDiagramEditPart().getDiagramPreferencesHint() ); <br>
<br>
viewDescriptor.setPersisted(true);<br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;<br>
<br>
CreateViewRequest createRequest = new
CreateViewRequest(viewDescriptor);<br>
<b>createRequest.setLocation(s.getLocation());<br>
createRequest.setSize(s.getSize());</b><br>
//command to add the element to the model<br>
Command c = new Command(){<br>
&nbsp;&nbsp; &nbsp;@Override<br>
&nbsp;&nbsp; &nbsp;public void execute() {<br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;AbstractEMFOperation emfOp = new
AbstractEMFOperation(editor.getEditingDomain(), "Insert sketched
element") {<br>
<br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;@Override<br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;protected IStatus doExecute(IProgressMonitor monitor,
IAdaptable info) throws ExecutionException {<br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;<br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;DiagramImpl n =
(DiagramImpl)editor.getDiagramEditPart().getModel();<br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;Diagram s = (Diagram) n.basicGetElement(); <br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;<br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;s.getShapes().add(unknown_element);<br>
<br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;return Status.OK_STATUS;<br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;}<br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;};<br>
<br>
<br>
&nbsp;&nbsp; &nbsp;try {<br>
&nbsp;OperationHistoryFactory.getOperationHistory().exec ute(emfOp,
null, null);<br>
&nbsp;&nbsp;&nbsp; } catch (ExecutionException e) {}<br>
&nbsp;&nbsp;&nbsp; }<br>
&nbsp;&nbsp;&nbsp; };<br>
<br>
editor.getDiagramEditDomain().getDiagramCommandStack().execu te(c); <br>
editor.getDiagramEditDomain().getDiagramCommandStack().execu te(editor.getDiagramEditPart().getCommand(createRequest)); <br>
</small><br>
<br>
<br>
Thank you!<br>
</tt>
</body>
</html>
Re: Creating EditPart + setting size no longer working [message #661833 is a reply to message #661637] Mon, 28 March 2011 07:34 Go to previous messageGo to next message
Matthias Kloppenborg is currently offline Matthias KloppenborgFriend
Hello Ugo.
Maybe this might help you to solve the problem.
There are inner ...Figure classes in the EditParts.
Have a deeper look at the createContents functions there.
Maybe this was changed by regenerating the code.
Greetings Matthias
Am 25.03.2011 17:09, schrieb Ugo Sangiorgi:
> Hello, after re-generating my code my CreateViewRequest seems to be
> I've checked over and over to see if there is something i forgot to mark
> ((IHintedType)ShapesElementTypes.Unknown_2003).getSemanticHi nt(),
> CreateViewRequest createRequest = new CreateViewRequest(viewDescriptor);
> *createRequest.setLocation(s.getLocation());
> createRequest.setSize(s.getSize());*
> @Override
> AbstractEMFOperation(editor.getEditingDomain(), "Insert sketched element") {
> @Override
> protected IStatus doExecute(IProgressMonitor monitor, IAdaptable info)
> DiagramImpl n = (DiagramImpl)editor.getDiagramEditPart().getModel();
> try {
> OperationHistoryFactory.getOperationHistory().execute(emfOp, null, null);
> Thank you!
Re: Creating EditPart + setting size no longer working [message #661927 is a reply to message #661833] Mon, 28 March 2011 14:26 Go to previous message
Member
--------------090302040905060902070400
Thanks Matthias, I looked all over, the figure is the same.
something is generated differently from previous version, and I cant
tell what is it.
The thing is that is an SVG figure, when I construct the Figure I do:
public SVGSketchFigure(RenderedImage i) {
super(i, false, true, true);
Unknown model = (Unknown) ((ShapeImpl) getModel())
.basicGetElement();
this.image = i;
this.setMaintainAspectRatio(true);
this.setRenderedImage(image);
createContents();
this.setLayoutManager(new StackLayout() {
public void layout(IFigure figure) {
*Rectangle r = figure.getClientArea();*
This figure.getClientArea() returns differently between the two versions
(original and re-generated).
I'm clueless.
Thanks anyway ^^
Le 28/03/11 09:34, Matthias Kloppenborg a
Previous Topic:Question according to http://wiki.eclipse.org/GMF_Constraints
Next Topic:GMF in eclipse 3.6 SR2
Current Time: Sat Dec 07 08:46:22 GMT 2024
Powered by FUDForum. Page generated in 0.03021 seconds
